does the type R LSD...
Old Nov 22, 2003 | 02:36 PM
kool168's Avatar
Default does the type R LSD...
can i install the DC2 type R LSD or Civic type R LSD into the del sol or SIR tranny?
also just wanna make sure the del sol or SIR tranny dun have LSD rite?
Old Nov 22, 2003 | 02:39 PM
chad's Avatar
Moderator
Default Re: does the type R LSD... (kool168)
NO!
you must use a type R or GSR ring gear and counter shaft
best thing to do
4.785 final drive with itr lsd....that will fit with no mods
Old Nov 22, 2003 | 04:34 PM
kool168's Avatar
Default Re: does the type R LSD... (chad)
um... kinda hard understand...
so here i have a SIR tranny, so if i wanna install a LSD into a SIR tranny, i will have to get a JDM ITR final gear set and ITR LSD, is that wut are you are saying?
thank you for the reply
Old Nov 23, 2003 | 04:14 AM
kool168's Avatar
hello?
Old Nov 23, 2003 | 07:57 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kool168 &raquo;</TD></TR><TR><TD CLASS="quote">um... kinda hard understand...
thank you for the reply </TD></TR></TABLE>
yes as long as your tranny is hydro.....
Old Nov 23, 2003 | 08:13 AM
Del Sol SiR's Avatar
I think any B Series hydro tranny will bolt up to any B Series engine...
Old Nov 23, 2003 | 01:24 PM
chad's Avatar
Moderator
Default Re: (DelSolSiR)
any b series tranny will mount up to any b series engine...PERIOD....but depending on hydro or cable tranny equiped cars, you will want to get same for your car or contact HASPORT and they have kits that allow you do to reverse swaps..
Old Nov 23, 2003 | 01:33 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolSiR &raquo;</TD></TR><TR><TD CLASS="quote">I think any B Series hydro tranny will bolt up to any B Series engine...</TD></TR></TABLE>
true, but that doesn't mean the internals are interchangable
Old Nov 23, 2003 | 02:39 PM
spoonek4's Avatar
Default Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
true, but that doesn't mean the internals are interchangable</TD></TR></TABLE>
Exactly.
I planned to install the ITR LSD into my 00' SiR S4 tranny awhile ago. Found out that I need a big size 4.4 ring gear & counter shaft off from a GSR/CTR/ITR. Or it's not gonna fit into my tranny.
I thought that since I'm changing those parts already. Why not changing it to 4.785 gear set at the same time? So I decided to upgrade to 98spec 4.785 gear set after all. Except the ring gear, counter shaft, u also need a diff 1st gear with needle bearing & bearing collar.
Old Nov 23, 2003 | 09:47 PM
kool168's Avatar
Default Re: (spoonek4)
um...
so the procedure of installing the ITR LSD into a SIR tranny, i will need the ITR LSD, final gear set, and counter shaft?
but i dun know if i have the hydro or cable tranny equipped...
so if my tranny is cable, then it is impossible to install the ITR LSD ?
Old Nov 23, 2003 | 09:49 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (kool168)
how do you not know???
Hw is the clutch fork moved....a cable, or with a slave cylinder?? What car
Old Nov 23, 2003 | 09:53 PM
Echo7847's Avatar
What year/car is the tranny from and whats the code?
Old Nov 23, 2003 | 09:54 PM
kool168's Avatar
it's a JDM B18C engine with a SIR or Del Sol tranny
i dun know..
the guy who do the swap for me told me that it is a SIR or Del Sol tranny...
i was planning to save some money on the swap, so i use the B16A2 tranny instead of the Type R tranny
but now i find out that it is kinda hard to drive since the wheels always spin and burn the tire when i step the gas panel all the way down.... and the turning is not so good....
Old Nov 23, 2003 | 09:58 PM
MaxSterling's Avatar
integra hydrotranny have different internals than civic...thus LSD for integra's dont work on civic hydrotranny
Old Nov 23, 2003 | 11:22 PM
kool168's Avatar
Default Re: (MaxSterling)
oh... so it is impossible to install the ITR LSD into my tranny?
that's sad...
wut about i move everything from the ITR tranny into my gear box?
are those gear box the same?
coz my friend's ITR's tranny has crack on it and the transmission oil is leaking
and he will change the new tranny...
so i can take everything from his crack tranny and change it to my tranny
does it work?
Old Nov 24, 2003 | 01:41 AM
94DelSlow's Avatar
Ive got an CTR LSD in my B16A2 Del Sol. Works great. They had to swap some ring from a GSR to make it fit, but other than that it runs like a champ
Old Nov 24, 2003 | 04:34 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kool168 &raquo;</TD></TR><TR><TD CLASS="quote">can i install the DC2 type R LSD or Civic type R LSD into the del sol or SIR tranny?</TD></TR></TABLE>
YES. But:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">you must use a type R or GSR ring gear and counter shaft
best thing to do
4.785 final drive with itr lsd....that will fit with no mods</TD></TR></TABLE>
Old Nov 24, 2003 | 05:22 AM
2000blackgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxSterling &raquo;</TD></TR><TR><TD CLASS="quote">integra hydrotranny have different internals than civic...thus LSD for integra's dont work on civic hydrotranny</TD></TR></TABLE>
Have you read the post at all? To get the ITR LSD to work in a SiR or Del Sol tranny you need
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chad &raquo;</TD></TR><TR><TD CLASS="quote">you must use a type R or GSR ring gear and counter shaft
best thing to do
Or are you talking about a d-series tranny?
Old Nov 24, 2003 | 07:17 AM
Why don't you just swap the trans ? Dump the SiR tranny and install the DC2 tranny... From what I understand, the SiR tranny has the same gearing as the DC2, the difference is the LSD. Right ?
Old Nov 24, 2003 | 07:26 AM
Targa250R's Avatar
be professional
He said the ITR tranny case is cracked.
Old Nov 24, 2003 | 07:45 AM
chad's Avatar
Moderator
Default Re: (Targa250R)
then all he has to do is swap cases!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">He said the ITR tranny case is cracked.</TD></TR></TABLE>
Old Nov 24, 2003 | 08:45 PM
kool168's Avatar
Default Re: (chad)
so the DC2 and SIR tranny's cases are the same?
and i can replace everything inside SIR tranny with DC2 tranny?
Old Nov 24, 2003 | 09:14 PM
spoonek4's Avatar
swap the tranny case means it's like "changing the tranny's cover". Use the SiR tranny's "cover" and put that on to the DC2's tranny's "base".
Also maybe u have to adjust your driving a lil bit too? The tires will still spin if u step your gas pedal all the way down. It's just that both wheels will spin together after u got the LSD. Maybe try to be a accelerate or corner lil bit smoother.
I'm not a great driver either so don't mean to lecture u here.
Old Nov 25, 2003 | 05:43 PM
kool168's Avatar
alrite, thankz people
Old Nov 25, 2003 | 06:37 PM
Nextelbuddy's Avatar
what abot a DC2 type r LSD unit into a 2001 gsr tranny? will that fit with no mods?
