brighter cluster bulbs
Old Nov 22, 2003 | 01:17 PM
crxgator's Avatar
Default brighter cluster bulbs
anyone know a number that will work with our guage clusters to make them brighter...
Old Nov 22, 2003 | 01:49 PM
dohcnotec's Avatar
Default Re: brighter cluster bulbs (crxgator)
i have a site on my computer that sells leds that fit. I'll post it when i get home
Old Nov 23, 2003 | 11:09 AM
crxgator's Avatar
Default Re: brighter cluster bulbs (dohcnotec)
i see...
Old Nov 23, 2003 | 01:25 PM
JaredH's Avatar
post it
Old Nov 23, 2003 | 05:37 PM
crxgator's Avatar
Default Re: brighter cluster bulbs (JaredH)
w3rd...anyone have any other ideas either?
Old Nov 23, 2003 | 08:14 PM
b16_madman's Avatar
I decided that ours were dark also, and I want a good backlit face so... I'm not going with the jdm cluster, and try and pick up a 94-01 teg gsr cluster or type r one, but don't really matter to me jdm or not. They have a good look at night, and make all bulbs red mmmm very nice.
Old Nov 23, 2003 | 09:11 PM
Vera's Avatar
i am looking for some bulbs to make it brighter as well ...
thanx
Old Nov 23, 2003 | 09:34 PM
racerus's Avatar
Yes me too,which bulbs will make them brighter.
Old Nov 24, 2003 | 11:25 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (racerus)
i opened mine up, and took the blue rubbers off my bulbs.. also at the top of the hood, took off the blue or it might of been amber transparent sheild off the top, and it was defenetly brighter.. but now, im a JDM *****.. haha
Old Nov 24, 2003 | 12:48 PM
temp's Avatar
Default Re: (Built B16A)
why not use the white LED bulbs from a photon style light?
Old Nov 24, 2003 | 02:56 PM
Wicked_CRX's Avatar
Default Re: (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">why not use the white LED bulbs from a photon style light? </TD></TR></TABLE>
Are you talking about the little raver lights!?
Old Nov 24, 2003 | 03:33 PM
B2FiNiTY's Avatar
Default Re: (Wicked_CRX)
I changed 3 of the 194 bulbs in the back and it was a lot brighter but the problem is that the cluster uses more than just 3 bulbs like the Integra so it appeared like bright spots on the cluster. There are many small ones that I do not know the size of.
Old Nov 24, 2003 | 03:41 PM
ElementMotor's Avatar
Default Re: (B2FiNiTY)
I just took off the orangish/amber colored plastic piece on the top of the cluster and it made a big difference, here take a look:
Old Nov 24, 2003 | 03:59 PM
crxgator's Avatar
what bulbs uses 194, i tried to fit them in there, and it wont work...
Old Nov 24, 2003 | 04:00 PM
crxgator's Avatar
Default Re: (EF8 ownz u)
hmm...ill go try that out in a minute
Old Nov 24, 2003 | 04:32 PM
ZC88CRX's Avatar
Default Re: (crxgator)
so how exactly do you do this? cause i cant see **** on my cluster at night
Old Nov 24, 2003 | 11:31 PM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8 ownz u &raquo;</TD></TR><TR><TD CLASS="quote">I just took off the orangish/amber colored plastic piece on the top of the cluster and it made a big difference</TD></TR></TABLE>
Thats what i was refering too.. but, it only brightens up the face.. not the backlight. but works..
Old Nov 25, 2003 | 05:57 AM
Mr Furball's Avatar
If your going to take the amber plate off you should try to take out the bulbs and just pull the amber coating off thats on the bulb itself.
It's like a little rubber condom thats on the bulb, just roll off.
Old Nov 25, 2003 | 06:59 AM
temp's Avatar
well i found out last night, it uses a #74 bulb
Old Nov 25, 2003 | 07:00 AM
temp's Avatar
to put it very simply........yes, the white light that is output by those is a decent color and would look nice in a CRX cluster
Old Nov 25, 2003 | 07:01 AM
nautica_t's Avatar
Default Re: (FURBALL B-16)
thats nice still, i did something else, i pulled out all the bulbs out of my cluster and put something else in, check mine out. by the way sorry for the large picture, and um, its actually pretty bright and clear at night.
Old Nov 25, 2003 | 07:22 AM
crxgator's Avatar
Default Re: (nautica_t)
wow thats worse than stock...
temp's Avatar
how did you do that? what did you use?
Old Nov 25, 2003 | 07:35 AM
virginia_dude's Avatar
you will be highly dissappointed in LED's the light dispertion patterns are not the same as a incandescent lamp. THis was done last year on a Mercedes board I belong to and the results are NOT like you are hoping for.
Old Nov 25, 2003 | 07:37 AM
temp's Avatar
Default Re: brighter cluster bulbs (virginia_dude)
you sure? i am sure that if you used LED's and removed the that piece of plastic like in the pic above it would be pretty nice
