abs tank empty
Old Nov 22, 2003 | 12:25 PM
yeroc1313's Avatar
Default abs tank empty
i had my abs system replaced a year ago at the dealership and then 10 months later it went again. the abs light is on and the tank is empty. when i fill it it leaks all over. it looks like it leaks from where the lines connect into the motor. is it worth getting fixed again or is it possible to just pull it out? thanks for the help
Modified by yeroc1313 at 4:42 PM 11/22/2003
Old Nov 22, 2003 | 02:06 PM
Nick H's Avatar
New User
Default Re: abs tank empty (yeroc1313)
yank that ******...it's more fun to run without it anyways...
Old Nov 22, 2003 | 02:53 PM
yeroc1313's Avatar
Default Re: abs tank empty (Nick H)
im a mechanic but i cant find what i need to so i know how to yank it out. have any ideas on where i can find it?
Old Nov 22, 2003 | 04:20 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeroc1313 &raquo;</TD></TR><TR><TD CLASS="quote">when i fill it it leaks all over. it looks like it leaks from where the lines connect into the motor. </TD></TR></TABLE>
Are the lines tight? Crossthreaded? Cracked lines? If that's where it's leaking it should be easy to figure out.
Old Nov 23, 2003 | 12:23 PM
yeroc1313's Avatar
Default Re: abs tank empty (Chiovnidca)
from what i can tell everything is tight. i had the dealership replace it, so im assumming that everything was done correctly. i would liek to take it out but im not sure how big of a project im askin for. have any ideas?
Old Nov 23, 2003 | 12:28 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeroc1313 &raquo;</TD></TR><TR><TD CLASS="quote">i would liek to take it out but im not sure how big of a project im askin for. have any ideas? </TD></TR></TABLE>
If you don't want ABS anymore, just pull the fuses.
Old Nov 23, 2003 | 03:53 PM
yeroc1313's Avatar
i did that a long time ago i was wondering if ti was at all possible to remove the system from the car completely
Old Nov 23, 2003 | 05:28 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeroc1313 &raquo;</TD></TR><TR><TD CLASS="quote">i did that a long time ago i was wondering if ti was at all possible to remove the system from the car completely
The brake lines would have to be modified or replaced. Also I think you would need to install a proportioning valve since the ABS modulator performs it's function. (I think so on your model but i'm not 100% sure.)
Old Nov 24, 2003 | 03:02 PM
yeroc1313's Avatar
ok thakns for the help that sounds liek way too much work for what its worth.
Old Nov 24, 2003 | 05:03 PM
RotaryBzzzz's Avatar
i would just leave it in and pull the fuse.
Old Nov 24, 2003 | 11:38 PM
Chiovnidca's Avatar
Default Re: abs tank empty (RotaryBzzzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzzz &raquo;</TD></TR><TR><TD CLASS="quote">i would just leave it in and pull the fuse.</TD></TR></TABLE>
That's what I said too. He doesn't seem to like any of my replies.
thegeezerkid
Jun 18, 2008 10:24 PM
LukieLuc
Mar 22, 2007 11:05 AM
nsxxtreme
Mar 10, 2006 09:05 AM
Darkray16
Feb 2, 2006 10:11 PM
Boosted00GSR
Jan 22, 2006 06:18 AM
