swapping 92 ls motor into 1991 Si
Old Nov 22, 2003 | 12:02 PM
b18c-rex's Avatar
Default swapping 92 ls motor into 1991 Si
im swapping a b18a1 into a 91 CRX si...i was just wondering how hard it is going to be to convert obd0 to obd1...if anyone done this all tips would help...thanks
Old Nov 22, 2003 | 12:33 PM
keithg's Avatar
Default Re: swapping 92 ls motor into 1991 Si (b18c-rex)
It would be easier (and cheaper) to change the injectors and distributor to non-obd (90-91 Integra) and use your stock engine harness. I think the only mods to your stock harness would be to lengthen a few wires.
Old Nov 22, 2003 | 01:43 PM
dohcnotec's Avatar
Default Re: swapping 92 ls motor into 1991 Si (keithg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithg &raquo;</TD></TR><TR><TD CLASS="quote">It would be easier (and cheaper) to change the injectors and distributor to non-obd (90-91 Integra) and use your stock engine harness. I think the only mods to your stock harness would be to lengthen a few wires.</TD></TR></TABLE>
I'm pretty sure you can just use your stock si injectors in the ls manifold. If you don't want to, just bypass the injector resistor box and keep the 92 injectors and you'll be fine.
Old Nov 22, 2003 | 02:07 PM
keithg's Avatar
Default Re: swapping 92 ls motor into 1991 Si (dohcnotec)
Good idea to keep the stock Si injectors, I don't think the 92 obd1 ls injectors will plug in or work with the Si harness.
Old Nov 22, 2003 | 08:59 PM
PHiZ's Avatar
http://b16a.honda-perf.org/wiring.html
http://www.geocities.com/kurtsi_on/page7.html
http://www.geocities.com/chipm....html
I could explain it all, but I'm lazy, these guys are talking about swappign a vtec engine into an OBD0 crx. But it is very similar to what you are doing.
-PHiZ
Old Nov 22, 2003 | 11:00 PM
dohcnotec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithg &raquo;</TD></TR><TR><TD CLASS="quote">Good idea to keep the stock Si injectors, I don't think the 92 obd1 ls injectors will plug in or work with the Si harness.</TD></TR></TABLE>
Yeah... I'm assuming you have the obd1 plugs/harness along with the engine
Old Nov 23, 2003 | 02:17 PM
b18c-rex's Avatar
i have a 92 ls and a 91 crx...i have everything based on that i have the car..thanks for all the help
wezzer577
Dec 29, 2008 05:29 PM
getnasty
Jun 14, 2005 08:20 PM
Shambro84
May 10, 2004 01:11 PM
XzzYzzX
May 17, 2003 05:22 PM
Flexmyrex
Jun 20, 2002 06:33 AM
