all 4 cyl. mis-firing.????
Old Nov 22, 2003 | 11:17 AM
baonest1's Avatar
Default all 4 cyl. mis-firing.????
so last night some jackass swapped the plug wires on the dist.
i didnt know this til i went to my friends shop and scanned the CEL that came on. at first we thought it was a fuel prob. anyway. we finally fix it and now the car shuts off when letting off the gas. its a stock d16 motor. could the valves be bent?? it turns on fine, revs fine. just cuts off.
we probably drove about 10 miles total (going to shop and back) while misfiring..
thanx for any help.
(and yes, i was PISSED last night)
Old Nov 23, 2003 | 12:05 AM
Mr. Choi's Avatar
New User
Default Re: all 4 cyl. mis-firing.???? (baonest)
maybe your wires are in the wrong hole. firing order is, 1-3-4-2
Old Nov 23, 2003 | 12:08 AM
spoon_ek9's Avatar
Default Re: all 4 cyl. mis-firing.???? (Mr. Choi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Choi &raquo;</TD></TR><TR><TD CLASS="quote">maybe your wires are in the wrong hole. firing order is, 1-3-4-2</TD></TR></TABLE>
i second that.
Old Nov 23, 2003 | 01:17 PM
baonest1's Avatar
Default Re: all 4 cyl. mis-firing.???? (spoon_ek9)
they are in correctly.. i searched and got the diagram of the dist. it turns on and revs fine. just when you let off the gas. it goes to idle and wants to shut off, but i tap the gas.
ima tighten the throttle cable a bit to hold it above stock idle
Old Nov 23, 2003 | 02:23 PM
G U E C O's Avatar
i third that
Old Nov 24, 2003 | 07:55 AM
baonest1's Avatar
Default Re: all 4 cyl. mis-firing.???? (stock93cx)
they wires are correct. i am telling you. i went over it 3-4 times.
blanco617
10
Mar 24, 2008 11:19 AM
Sean5826
Jul 24, 2007 10:58 PM
troi_oi
Nov 26, 2006 04:19 PM
billiardmaniac
Apr 28, 2003 03:57 AM
