wha kinda spark plugs should i use for b20 vetc compression 12.1
as the topic says what kinda spark plugs should i use for b20 vetc high with high compression pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_gsr »</TD></TR><TR><TD CLASS="quote">as the topic says what kinda spark plugs should i use for b20 vetc high with high compression pistons
Bosch #4227 works for me.....only $1.50 each...
the problem is my car was runnin good until it blew one of the spark plugs and now its detnating and i tryed changing a new coil pack just to see what diffrent it would made but its still the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 »</TD></TR><TR><TD CLASS="quote">switch to ngk bkr7's
Only prob... most places don't carry the 7's (not even Autobacs and they have rows & rows of spark plugs on display).... usually nothing higher than the 6's (where bkr5 is the "norm"). But a customer of our who we built a 12.5:1 comp LS/VTEC has been using the bkr6 plugs for 6 months now, from the hot summer to the cold fall nights now w/out any problems.
i built a 12.3:1 compression motor for a customer and he kept bitching about a misfire.... Changed the plugs to 7e's and problem was gone. Also he is a dumbass and he was running lean as **** for awhile so that didnt help...
These high compression motors are untamed beasts, every one is different and respondes different
sneakychaos
Nov 8, 2008 04:47 PM
