Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph?
Old Nov 22, 2003 | 05:50 AM
Spooled1.6L's Avatar
Default Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph?
Is there a trans that will bring that down? and does anyone know what trans that is that would make my car run like that? The car is a b16 with a Drag kit in an 3k, not sure on the trans, someone said it was a type r trans. I had a gsr before and it would be at 4,000 rpm at 80 mph in 5th
Old Nov 22, 2003 | 06:01 AM
b16ahybrid's Avatar
Default Re: Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph? (Spooled1.6L)
Well what size of wheels do you have?
Old Nov 22, 2003 | 06:40 AM
armrslr's Avatar
Default Re: Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph? (b16ahybrid)
Sounds to me like you have an SI tranny, but I could be mistaken. Type-R, GSR, and LS should never be that high of an rpm unless you have 15" rims with something like 205X30's on them. I'd definately have someone look at the tranny for you.
Old Nov 22, 2003 | 07:03 AM
Default Re: Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph? (armrslr)
they are 17' volks
Old Nov 22, 2003 | 07:56 AM
turbod16y8's Avatar
you probably going faster then wat the gauge says
Old Nov 22, 2003 | 09:31 AM
baphomet's Avatar
Default Re: Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph? (turbod16y8)
you could always put an LS 5th gear and syncro in it.
Old Nov 22, 2003 | 09:37 AM
Mr. Softee's Avatar
Default Re: Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph? (slashDEVslashNU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">you could always put an LS 5th gear and syncro in it.</TD></TR></TABLE>
Old Nov 22, 2003 | 09:54 AM
thats true, How much faster do you think it could be thrown off?
Old Nov 22, 2003 | 10:17 AM
ScottEK's Avatar
B16 S1 trans (Same as ITR gearing) is at about 5000RPMs at 80mph
Old Nov 22, 2003 | 01:38 PM
Quick 200k Mile Motor's Avatar
hydraulic, not cable
Old Nov 22, 2003 | 02:44 PM
PM-Performance's Avatar
Default Re: Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph? (Quick 200k Mile
my itr is 4250RPM's at 80mph. all the b16's i have driven were right about the same .
you must have a JDm fd in it or something
Old Nov 22, 2003 | 03:02 PM
Tinker219's Avatar
my h22 w/f22 trans is around 3200rpm at 80mph. You think its hard not to speed in any of the B series, try droning along just barely off-idle...lol. BTW, 60mph is around 2200 rpm...lol
205/50/15s
*edit* WAS that stuff up above before I blew the **** out of it
Old Nov 22, 2003 | 09:51 PM
Jkan2001's Avatar
I feel your pain, i have a hx tranny in my y8 and i'm around 3000 going 80 in 5th.
My freaking 3rd gear goes to 112 mph
stupid econo oriented setup
Old Nov 23, 2003 | 12:27 AM
Kwuaymaikrup's Avatar
I was running a B16 cable trans (non-LSD) on my old setup and was at 4,400 at 70mph with 17's. I would say go witht he LS 5th.
-Ryan
Old Nov 23, 2003 | 01:10 AM
Unsung's Avatar
Does anyone make an aftermarket final drive to make all the gears stretch a little longer?
Old Nov 23, 2003 | 04:43 AM
Jay J's Avatar
Prince of Zamunda
Default Re: Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph? (Unsung EM1)
The LS tranny sounds like a better idea
Old Nov 23, 2003 | 07:28 AM
mos's Avatar
mos
Default Re: Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph? (neuspeed)
I will gladly trade you for my LS trans.
Old Nov 23, 2003 | 07:44 AM
patdemps's Avatar
Default Re: Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph? (mos)
My ITR tranny setup had a 4.785 FD. When I was at 70mph I was around 4.1k. Thats with 16 inch rota circuit 8's aswell. Its very easy to stay around the speed limit with a high FD.
Old Nov 23, 2003 | 08:54 AM
Stein's Avatar
Default Re: Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph? (patdemps)
Isn't it better to have a LS or GSR tranny for turbos?
Old Nov 23, 2003 | 09:05 AM
HYBRID_H@TCH's Avatar
Default Re: Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph? (Stein)
I have a gsr tranny with 205-50-15's and at 80 mph Iam at 4100 rpm.
Old Nov 25, 2003 | 07:25 AM
armrslr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Isn't it better to have a LS or GSR tranny for turbos?</TD></TR></TABLE>
Generally speaking yes it is better. Once you can actually learn how to optimize each gear, then you will see how much more potential there is out there other than an LS tranny. Imagine every gear pulling like 1st and 2nd....................
Old Nov 25, 2003 | 09:08 AM
BoostedGSRBubble's Avatar
Ummmmmm, no. This has been discussed countless times on here. If you want the fastest 1360 possible, then the ls isnt for you.
ls - ggod - maybe its nice for cruising
gsr - better - good compromise between ls and itr
itr/si - best - a blast to drive and ripps
custom gearing (itr tranny w/ ls fifth) is truly the best of both worlds but i have never driven one. My itr tranny is at 4250 @ 80mph.
Old Nov 25, 2003 | 09:20 AM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Turbo car Gearing? I can't cruise on the highway, im at 5,500rpm in 5th@80mph? (BoostedGSRBubbl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedGSRBubble &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
who races 40 feet passed the traps??
Old Nov 25, 2003 | 09:36 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com &raquo;</TD></TR><TR><TD CLASS="quote">
who races 40 feet passed the traps?? </TD></TR></TABLE>
LOL LOL
i have a gsr trans sitting up here if anyone wants to make a deal.
Old Dec 1, 2003 | 07:28 AM
armrslr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Ummmmmm, no. This has been discussed countless times on here. If you want the fastest 1360 possible, then the ls isnt for you.</TD></TR></TABLE>
Who said anything about me running the fastest 1320? I run mostly on the street/interstate. The SI tranny is garbage.........gears are wayyyyy too close, you have to shift wayyyyy too fast, synchros go out like light bulbs .....................need I go on?
Modified by armrslr at 11:59 AM 12/1/2003
