Ignition and fuel pump cut? wiring questions
Old Nov 22, 2003 | 02:12 AM
PM-Performance's Avatar
Default Ignition and fuel pump cut? wiring questions
Ok im paranoid as hell now , one of my friends cars got stolen like a few blocks form my house. So i was thinking of adding a fuel pump cut and igntion cut for the R just in case.
could i just take the fuse out of the fuse box and put a toggle switch inline with the fuse box? or is there any other suggested way to do this?
Also i think it was Ignited makes a special key type deal ignition cut he actually got for one of his other cars, but he said he couldnt use it in his race car becuase its no SFI certified. I was thinking of using thta too, but not sure if they will give me tech probs.
Old Nov 22, 2003 | 02:48 AM
uNF$@#!'s Avatar
Default Re: Ignition and fuel pump cut? wiring questions (itr206)
if youre really looking to do this, let a professional do it...though it wont save your car imo.
if i was a thief around PA, i'd just tow it away.
Old Nov 22, 2003 | 03:00 AM
Default Re: Ignition and fuel pump cut? wiring questions (Soup ****)
yea but most people at the mall and such dont have access to tow it . if someone is gonan tow your car to steal it more than likely they scout you and see you in a certain spot everyday for set times and **** and set it up , im sure you wont be at Walmart one night and someone see your car in the lot and quick run home for a tow truck or flat bed or something . Take too much time. If someone is gonna steal my car i atleast want thme to work for it, I fi had to work for it , **** they will too . Not getting it without a fight. plus there are no real big car theives around me , its all low time dousche bags from the projects and ****. No real professionals.
but anyway Thanks for the great advice rather than help . I figured out the fuel pump kill swx, seems easy. Do you think its worth it to put an ignition kill switch in there too? there was alot of **** changed up with that when i put my MSD in .
If i did decide to put ignition cut in there too , could i just tap into onr of the power wires tothe MSD? If thats cut off it wont trigger anything if im correct no matter what they **** wiuth under the dash .
Modified by itr206 at 4:15 AM 11/22/2003
Old Nov 22, 2003 | 12:36 PM
mist sITR's Avatar
i put a fuel cut off switch on my car last night peace O cake
new idea i heard the other day
tapped into the wire that connects to your clutch sencer and installed a switch there. so esenulay u can't start the car because it will never read the clutch as being pushed it (which is needed to start a manuel)
Old Nov 22, 2003 | 12:53 PM
itr-j's Avatar
Default Re: Ignition and fuel pump cut? wiring questions (mist sITR)
it helps i have it but then its not like something that makes it super good
Old Nov 22, 2003 | 02:00 PM
Default Re: Ignition and fuel pump cut? wiring questions (itr-j)
i got some switches today and wired one inline with the fuel pump and one inline with my MSD ignition power. I dont think anyone will wanna **** with that , once wrong move messing with that they will make the car not starting situation worse, lol. .
My friends whos CRX got stolen last night we put an Ignited set up in his Ek cuz he was worried abotut hat one too, real nice unit, it has like a arcade game type key that needs to be in and making contact to start the car. when the key is out it kinda looks lik e a cig lighter plug so its not conspicuos
jtheshowstopppe
Jan 2, 2016 08:28 PM
jianwa
Jul 31, 2010 02:03 PM
hazzy
Apr 26, 2010 08:15 PM
DsITR
Dec 3, 2003 10:27 PM
Puzzler
Sep 25, 2002 04:13 AM
