Curious about the 59300 zex cam
Old Nov 21, 2003 | 08:11 PM
trooper0641's Avatar
Default Curious about the 59300 zex cam
If i was to put this into a d16z6...would it pull as hard as a b16? Or even close to it?
Is this cam good for turbo?
Old Nov 21, 2003 | 08:37 PM
2000blackgsr's Avatar
Default Re: Curious about the 59300 zex cam (trooper0641)
This is not a good cam for turbo.
As for pulling like a B16, it depends on your other mods.
Old Nov 21, 2003 | 08:49 PM
Daniel's Avatar
Yeah, depends on what other mods are done to the motor as well as how well you get the setup tuned. Just the cam with no tuning won't yield great gains, but headwork and lots of tuning will help a lot. If anything else, your D-series will sound nice after VTEC x-over.
Old Nov 21, 2003 | 09:22 PM
Soccerking3000's Avatar
Default Re: Curious about the 59300 zex cam (Daniel)
ya i just got a zex cam but yet to install it but i have i/h/e and skunk2 intake manifold and h22 t/b on a d16z6 what could i expect and how would i go about tuning it???
Old Nov 21, 2003 | 09:28 PM
Daniel's Avatar
Default Re: Curious about the 59300 zex cam (Soccerking3000)
Cam gear, wideband O2 bung, dyno, wideband O2, good tuner, and something to change the fuel. In your case, you could probably get away with a VAFC. That's what I used when I used the Skunk2 Stage 1. Also used a Skunk2 cam gear and my tuner's wideband O2.
Old Nov 21, 2003 | 09:30 PM
how much would that cost a vafc et cetera cause i am not a millionare and im cheap
Old Nov 21, 2003 | 09:50 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">how much would that cost a vafc et cetera cause i am not a millionare and im cheap</TD></TR></TABLE>
Then good luck on finding horsepower from your setup. Assuming everything's brand new (VERY rough pricing)----
A'PEXi VAFC: $300
Skunk2 cam gear: $100
wideband O2 bung: $50
dyno tuning w/ a wideband O2 sensor: $100 x Hours (figure maybe 1.5-2 hours, sometimes less if the tuner is familiar with a setup similar to yours)
You can obviously buy some of this **** used to save money. Dyno tuning prices vary a lot. My shop charges around $100/hour, but some charge almost $150+/hour. Depends on the shop. Good luck.
Old Nov 22, 2003 | 11:27 AM
well that isn't that bad at all i was thinking like 500 and so one for the stuff thank you though
92hondaswap
Aug 16, 2008 05:35 PM
DavidT or VajT
Apr 3, 2005 06:32 PM
EGinNY
Oct 2, 2003 11:23 PM
JdMCiviCCupE
Jun 19, 2003 07:34 AM
tc
Aug 7, 2002 05:21 PM
