friends swap has no vtec
Old Nov 21, 2003 | 07:37 PM
HatchBox's Avatar
Skoobie no more...
Default friends swap has no vtec
alright my friend put a b16a1 in his little 91 hatch...it works fine but there isnt any vtec. and its not throwing any codes...what could it be? (i searched)
Old Nov 21, 2003 | 07:42 PM
Giuseppe's Avatar
Default Re: friends swap has no vtec (ind3ciso)
oil pressure? got enough oil?
ATS_Antone's Avatar
its usually one or more of these 3 things.
vtec oil pressure switch or wiring
tps signal or wiring or
vtec solenoid or wiring
Old Nov 21, 2003 | 07:44 PM
bossman032's Avatar
Default Re: friends swap has no vtec (antone)
It can also be that the car doesn't want to go in vtec right now but after driving for a while it will go in vtec what happened to me
Old Nov 21, 2003 | 07:49 PM
HatchBox's Avatar
Skoobie no more...
Default Re: friends swap has no vtec (Giuseppe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Giuseppe &raquo;</TD></TR><TR><TD CLASS="quote">oil pressure? got enough oil?
we put like 4 1/2 quarts of oil in it not sure bout the pressure
Old Nov 21, 2003 | 07:52 PM
Giuseppe's Avatar
try the above, and if that checks out..
do u have a VTEC ecu???
Old Nov 21, 2003 | 07:53 PM
HatchBox's Avatar
Skoobie no more...
Default Re: friends swap has no vtec (bossman032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">It can also be that the car doesn't want to go in vtec right now but after driving for a while it will go in vtec what happened to me </TD></TR></TABLE>
how long?
HatchBox's Avatar
Skoobie no more...
i saw it and it says b16 ef on it i can check to see if it is or not but were there b16s with no vtec???
Old Nov 21, 2003 | 07:55 PM
Giuseppe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote"> were there b16s with no vtec??? </TD></TR></TABLE>
nope, make sure its a pr3, or a pw0
1st gen that is
Old Nov 21, 2003 | 07:56 PM
HatchBox's Avatar
Skoobie no more...
its a PW0 ecu
Old Nov 21, 2003 | 07:59 PM
Giuseppe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">its a PW0 ecu</TD></TR></TABLE>
definitely a vtec ecu...
make sure its getting all the signals it needs..
is this a DIY install?? u sure u wired it up right?
Old Nov 21, 2003 | 08:00 PM
HatchBox's Avatar
Skoobie no more...
its a hasport vtec conversion harness
Old Nov 21, 2003 | 08:01 PM
Giuseppe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">its a hasport vtec conversion harness </TD></TR></TABLE>
sheesh...that puppy should fire right up!!!
Old Nov 21, 2003 | 08:03 PM
HatchBox's Avatar
Skoobie no more...
i know
Old Nov 21, 2003 | 08:04 PM
Giuseppe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">i know
im scratching my head too....
Old Nov 21, 2003 | 08:06 PM
Giuseppe's Avatar
ok, the harness that HASport gave you, does it have a plug that goes into
your TPS...u know where the TPS sensor is right??
Old Nov 21, 2003 | 08:09 PM
HatchBox's Avatar
Skoobie no more...
the harness goes to....
*knock sensor
vtec solinoid
vtec oil press switch
and second o2 sensor.
and ground
btw he convered to MPFI durin the swap. i belive u have to swtich the wires around on the tps for the dpfi-mpfi
Old Nov 21, 2003 | 08:11 PM
Giuseppe's Avatar
btw he convered to MPFI durin the swap. i belive u have to swtich the wires around on the tps for the dpfi-mpfi </TD></TR></TABLE>
thats where i was going...BUT if he already DID that....****!
Old Nov 21, 2003 | 08:13 PM
HatchBox's Avatar
Skoobie no more...
ok so say the wires arent in the right order what is the car going to do?
Old Nov 21, 2003 | 08:18 PM
Giuseppe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">ok so say the wires arent in the right order what is the car going to do?
never tried it out... when i did my swap i made sure everythign was done
once the first time...
Old Nov 21, 2003 | 08:19 PM
Giuseppe's Avatar
brainstorming, taking a long shot here...maybe a fried VTEC solenoid switch...?!?!
Old Nov 21, 2003 | 08:21 PM
HatchBox's Avatar
Skoobie no more...
if that was the case would the ECU throw a 21?
and if not ...how would it test it?
Old Nov 21, 2003 | 08:22 PM
Giuseppe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">if that was the case would the ECU throw a 21?
and if not ...how would it test it? </TD></TR></TABLE>
i dont have my ECU code sheet..whats 21 anyway..??
but if it was it, it would probably throw a code....
just check to make sure that those plugs are on tight, maybe ther arent in
all the way....
Old Nov 21, 2003 | 08:24 PM
HatchBox's Avatar
Skoobie no more...
21 is vtec solinoid
plugs are on
Old Nov 21, 2003 | 08:25 PM
Giuseppe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">21 is vtec solinoid
plugs are on </TD></TR></TABLE>
nobody is perfect, maybe..just maybe HASport fudged when they made the harness.
i mean, youre running out of options....
