98-01 CRV appears to use similar suspension as 99-00Si!
I was looking at a 98 CRV the other day at work, and I noticed the front suspension is a mirror image of the 99 Si I used to have in my garage. The LCA's are the same, and the swaybar size appears to be the same. I am wondering if the hubs are the same? Cuz the CRV does use 5 lug....if the back arms could be adapted to work with civic Si or CTR/ITR rear disc brakes there may be a cheaper way to get a 5 lug conversion. Plus, the front discs on the CRV look absofuckingloutly HUGE!
I wouldn't mind getting a pair of CRV front LCAs cheap from a junk yard, and also the front sway bar. From what I hear the front Si LCAs are lighter, and stronger...plus they allow you to use the larger Si swaybar. I knew I should have ripped that off the Si too when I had it.....
yh23
May 27, 2005 02:08 PM
enrique
Jan 23, 2003 10:20 PM
EricUSC
Jan 16, 2003 04:40 AM
