repacking rear wheel bearings
is this required as part of periodic maintenance? i noticed my left rear hub doesnt spin as freely as the other side. do i just remove the hub cover and pack some grease in there? any tips will be appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">is this required as part of periodic maintenance? i noticed my left rear hub doesnt spin as freely as the other side. do i just remove the hub cover and pack some grease in there? any tips will be appreciated</TD></TR></TABLE>
no they are seal bearings.....therefore you don't need to greese them
From: gravity rides everything...everything will fall, se GA/ne FL
i have a brand new set of itr hub/bearings for the rear if you want new ones. i will cut you a good deal.
pcorad
May 30, 2002 12:36 PM
