b16 exhaust
ANYBODY have problems with the b16a exhaust manifold sitting WAY to low and hitting? It hangs 3 inches lower than the stock si exhaust.
Is there a header that will sit higher up and not scrape ?
I have the stock exhaust manifold and downpipe on my b16a and it sits perfectly. It doesn't sit any lower than the oil pan or crossmember. You might have a 1.8L manifold on there. I know they definitely sit lower than the 1.6L manifold.
i suspect thats a GSR manifold that some china man slapped on there by accident.
Check to see If the clearance between the pan and the downpipe is excessive...
It should be no more than an inch......
hth
good luck!
hth
good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Giuseppe »</TD></TR><TR><TD CLASS="quote">i suspect thats a GSR manifold that some china man slapped on there by accident.
hth
good luck!
what the hell makes you think a china man did it? No I'm not chinese and sure hope you aren't either. You realize these cars are from japan?
hth
good luck!
So i always hear DC's are crap, but do you think it would be worth picking up a used one for the time being?? How much could i find one for , and what would i want to get, 4-1 or 4-2-1?
A few pics of your clearance and setup would be awesome
i've never heard anythign bad from dc's. you should prolly get the 4-1 header for more upper rpm power. you can prolly find one for about 150-225. i think you need the dohc vtec del sol header. could be mistaken
