Major Problem: 91 Teg w/ 94 GSR motor turbo, no fuel/pump not turning on. Please help if possible.
Old Nov 21, 2003 | 03:37 PM
AGS's Avatar
AGS
Default Major Problem: 91 Teg w/ 94 GSR motor turbo, no fuel/pump not turning on. Please help if possible.
We swapped a b18c1 from a 94 gsr into a 91 ls. now we turbo'd it and while the car was running my friend crimped a wire running to the idle control because the cars idle was bouncing. after the crimp the car shut off on its own and now we are unable to start it again (due to no fuel(we think)) also causing a pain in our asses is the fact that the vafc that was working perfectly is now not on and we are wondering if the ecu is even getting power now. all fuses have been checked and all wires that we can visibly see are not fried. injectors are good and injector box is good too. any idea what may have gone wrong? please help if you have alot of knowledge on the wiring or what you think is that problem. thanks.
Old Nov 21, 2003 | 09:01 PM
AGS's Avatar
AGS
Default Re: Major Problem: 91 Teg w/ 94 GSR motor turbo, no fuel/pump not turning on. Please help if possi
big problem needs to get fixed bump
Old Nov 22, 2003 | 01:23 PM
Audipwr1's Avatar
step 1.
test if you actually are getting fuel
if you are actualy getting spark
test timing
any cels?
you got no details man
Old Nov 24, 2003 | 04:42 AM
AGS's Avatar
AGS
Main relay was the problem. Its on the road and boosting now.
david420
Nov 17, 2012 07:46 AM
Bleezy
May 3, 2012 09:59 PM
WillM
Mar 7, 2012 03:17 PM
missionaryrider
Nov 5, 2007 03:34 PM
sexyblack93lude
Jul 18, 2005 05:03 PM
