Tokico HP or GR-2?
Will the KYB GR-2's work in the rear of a 4-Door 94 accord with Eibach Sportlines? I have a 1.8 Drop on my car and I wanted to get the lower valued shock. What's the difference if any between the two?
I got GR-2's on my accord right now. They are a good upgrade from stock thats about it. I got them with stock springs on them, only because my stock shocks were going bad. If you're going to use them for a drop that big def use the tociko's. If thats your only choices. I had Tociko blues with H&R's with a 1.75 drop a while back and that was pretty comfortable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KGAccord »</TD></TR><TR><TD CLASS="quote">neither strut is up for the task of a 1.5+ inch drop espcially the GR-2s since those aren't much better than stock.</TD></TR></TABLE>
tokico's good until 1 3/4 that's 1.75 inch(tokico blue hp)
then neither shock is suitable for youor desires.
get kyb agx, tokicoo illumina, koni yellow...
the gr-2 is an oem replacement shock, the tokico hp is a mild performance shock, and cant even compare to the 3 shocks i listed above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2+2=5 »</TD></TR><TR><TD CLASS="quote">
tokico's good until 1 3/4 that's 1.75 inch(tokico blue hp)</TD></TR></TABLE>
it's only warranteed for 1.5 inches or less. i have them with prokits 1.3 and that's about as much as they are good for. even still i wish i had something firmer.
Thanks. I wonder why NOPI didn't inform me of this. I need to leave them alone. I have just been waisting money left and right with them and not getting what I want.
EKB18BPR3
Mar 6, 2005 08:01 PM
