thermostat, does this happen to everyone?
Old Nov 21, 2003 | 12:39 PM
98cwitr's Avatar
Default thermostat, does this happen to everyone?
the needle on the temp gauge never reaches the half way point it always stays about 2mm before the half way point (on the cold side). This is normal, right?
Old Nov 21, 2003 | 12:40 PM
Bbasso's Avatar
Default Re: thermostat, does this happen to everyone? (98cwitr)
thats right.
Old Nov 21, 2003 | 12:53 PM
yoshi234's Avatar
I shoot brides
mine flunctuates
yshi - who can't wait to take out the sp00n t-stat (again) and throw it as far as possible
Old Nov 21, 2003 | 12:55 PM
type-r 01 886's Avatar
Default Re: thermostat, does this happen to everyone? (yoshi234)
if you have aftermarket headers or heatshield off it may run a little hotter
Old Nov 21, 2003 | 01:11 PM
98cwitr's Avatar
Default Re: thermostat, does this happen to everyone? (type-r 01 886)
i have A jdm dc header, nothing's changed...i guess thats a good thing
Old Nov 21, 2003 | 01:19 PM
Champ R's Avatar
When the weather is decently warm out, mine is in the same position always, but this cold weather has been making mine drop to the 1/8th point.
Old Nov 21, 2003 | 02:16 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoshi234 &raquo;</TD></TR><TR><TD CLASS="quote">yshi - who can't wait to take out the sp00n t-stat (again) and throw it as far as possible </TD></TR></TABLE>
LOL!
I just picked up a Mugen 'stat and thermo switch, to deal with my temp problem after a couple laps on the track.
Looks like I'll also need to also re-do the Hondata intake manifold gasket install so a to allow the original means of coolant flow through the head ...
Old Nov 21, 2003 | 03:02 PM
Austin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoshi234 &raquo;</TD></TR><TR><TD CLASS="quote">mine flunctuates
I thought that you had learned the first time...then my car ran too cold
Old Nov 21, 2003 | 03:12 PM
JjuuN R's Avatar
Default Re: thermostat, does this happen to everyone? (Austin)
perfectly normal, i got mine down from the normal postion (1 bar below half way) down like 4 bars from half way when i did my 155mph flyby for the video i'm shooting for my car
Old Nov 21, 2003 | 03:31 PM
Rhetoric's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">
I thought that you had learned the first time...then my car ran too cold </TD></TR></TABLE>
I have a Spoom thermostat and on the freeway its at the first line on the temp gauge
Ive been using it for 2 years and its about time to take it out.
Old Nov 21, 2003 | 04:49 PM
Arsenal's Avatar
Default Re: thermostat, does this happen to everyone? (Rhetoric)
Can you run too cold?
The reason I ask is that my car never goes even 1/8 of the way up, except at a long stop, but whenver its driving I am at the coolest line possible? I do have an aftermarket front bumper which lets in a lot more air, but I never seem to be fully warmed up
Old Nov 21, 2003 | 04:51 PM
nEoMuGen's Avatar
Default Re: thermostat, does this happen to everyone? (Arsenal)
same here, I'm afraid to use VTEC now, seems like swapping back the oem one for winter is the way to go.
Old Nov 21, 2003 | 10:33 PM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">Can you run too cold?
The reason I ask is that my car never goes even 1/8 of the way up, except at a long stop, but whenver its driving I am at the coolest line possible? I do have an aftermarket front bumper which lets in a lot more air, but I never seem to be fully warmed up </TD></TR></TABLE>
It is possible to run too cold and lose power as well as use more fuel.... this is due to the fact that the ECU will sense that the car is running cold and may use a richer map....
I think the guys at P1 showed that it was best to use an OEM thermostat on the street and will only be beneficial to those in hot climates and or HPDE + track racing.
Old Nov 24, 2003 | 05:04 AM
canuck-mx6's Avatar
hehehe, my spoon thermo stat makes my gauge do the same thing. I tired driving the car when its cold outside (0-10 c), and the car never warms up. ECU stays on the cold start maps :"(
Old Nov 24, 2003 | 08:27 AM
iperez's Avatar
I have the Mugen t-stat and the Mugen radiator cap. Everything seems to work just fine. I'm just curious, should I swap the thermo-switch for the Mugen part or am I OK using the OEM t-switch ?
Old Nov 24, 2003 | 08:45 AM
chad's Avatar
Moderator
Default Re: (iperez)
you stock temp guage on your dash will move once car hits about 212 degrees....when it is just under hot you are at 222.....fully pegged it would be at or above 250 degrees....yes i did see this....and no didn't blow anything up!
Old Nov 24, 2003 | 08:54 AM
Tweakmeister's Avatar
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">you stock temp guage on your dash will move once car hits about 212 degrees....when it is just under hot you are at 222.....fully pegged it would be at or above 250 degrees....yes i did see this....and no didn't blow anything up!</TD></TR></TABLE>
did your shoes start melting?
eric416
Feb 5, 2008 07:40 AM
gary201147
Jul 9, 2007 02:04 PM
1mouatyme
10
Jun 8, 2006 11:09 AM
HatchedGTI
Feb 10, 2006 10:47 AM
kaj
Apr 17, 2003 04:53 PM
