CONFUSED: whats involved in resizing rod bolts when installing ARP rod bolts??
Old Nov 21, 2003 | 11:56 AM
Propulsion's Avatar
Default CONFUSED: whats involved in resizing rod bolts when installing ARP rod bolts??
Looking to do this in a b20z, do I need to take the pistons/rods out of the block and send them to a machine shop along w/ the bolts?
does this mean that the block will need to be honed again before reinstalling the pistons?
could someone tell me step by step what needs to be done so that its done right?
Old Nov 21, 2003 | 02:28 PM
non-VTEC's Avatar
Default Re: CONFUSED: whats involved in resizing rod bolts when installing ARP rod bolts?? (SilverCIVIC96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCIVIC96 &raquo;</TD></TR><TR><TD CLASS="quote"> do I need to take the pistons/rods out of the block and send them to a machine shop along w/ the bolts?
yes
you should install new rings at the same time so honing the cylinders would be a excelent idea.
BUT if you are gonna go through the trouble of pulling the rods out just to install new bolts you might as well replace the pistons for more compression.......
also dont forget new rod bearings.......
Old Nov 22, 2003 | 11:13 AM
3rdGteg's Avatar
Default Re: CONFUSED: whats involved in resizing rod bolts when installing ARP rod bolts?? (non-VTEC)
I wonder....after getting the rods resized when using ARP rod bolts.....would you then have to use thicker bearings or not?
Since you are taking material off of the rod's bore wouldn't you need thicker bearings afterwards?
Old Nov 22, 2003 | 12:56 PM
HONDADNA's Avatar
Default Re: CONFUSED: whats involved in resizing rod bolts when installing ARP rod bolts?? (3rdGteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg &raquo;</TD></TR><TR><TD CLASS="quote">I wonder....after getting the rods resized when using ARP rod bolts.....would you then have to use thicker bearings or not?
Since you are taking material off of the rod's bore wouldn't you need thicker bearings afterwards?</TD></TR></TABLE>
Yes, you do have to use larger bearings. If you don't have the right tools nor have ever done this your self; I recommend sending the crack as well to the machine shop of bearing resize.
Old Nov 22, 2003 | 01:40 PM
NJIN BUILDR's Avatar
Default Re: CONFUSED: whats involved in resizing rod bolts when installing ARP rod bolts?? (HONDADNA)
When rods are resized material is machined off the parting faces of the cap and rod(usually around .003").When the rod is reassembled it is slightly oval.Its then bored or honed back round and to original size.The reason for resizing after using performance rod bolts is because they usually have more press fit and distort the bore.Depending on the final size of the rod,the bearings may need to be larger OR smaller.
Old Nov 22, 2003 | 06:18 PM
AzG35's Avatar
Default Re: CONFUSED: whats involved in resizing rod bolts when installing ARP rod bolts?? (NJIN BUILDR)
A normal resizing job does not take very much off of the rod end. No, you don't need to use oversize bearings, ACL's that I have used with resized rods fit well within spec.
Old Nov 22, 2003 | 06:27 PM
3rdGteg's Avatar
Default Re: CONFUSED: whats involved in resizing rod bolts when installing ARP rod bolts?? (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">A normal resizing job does not take very much off of the rod end. No, you don't need to use oversize bearings, ACL's that I have used with resized rods fit well within spec. </TD></TR></TABLE>That was exactly what I wanted to know; because the standard acl will fit within clearance now, but I was worried that it might not after I get the rod resized. Excellent info
Old Nov 22, 2003 | 07:46 PM
aeolus's Avatar
If the machine shop does it right,it shouldnt change much.Why not just get a set of eagle rods,im sure for as much money your gonna spend on rod bolts,installing,resizing,you might as well just get a set of whole new rods.
Old Nov 22, 2003 | 10:05 PM
3rdGteg's Avatar
Default Re: CONFUSED: whats involved in resizing rod bolts when installing ARP rod bolts?? (aeolus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeolus &raquo;</TD></TR><TR><TD CLASS="quote">Why not just get a set of eagle rods,im sure for as much money your gonna spend on rod bolts,installing,resizing,you might as well just get a set of whole new rods.</TD></TR></TABLE>don't know bout the original guy who posted, but I was planned on using oem pistons w/ the pressed wrist pins...
Old Nov 23, 2003 | 01:37 AM
VtecDA9's Avatar
Bolts cost like $40 and resizing cost another $40 roughly = $80. Rods cost at least $350. Depends on what he wants to do with his application. Those were my costs, but shouldn't be too far off any where else.
Old Nov 23, 2003 | 08:59 AM
aeolus's Avatar
ok,then if its stock pistons you are gonna use,then i guess you might not have much of a choise,i also suggest shot-peening them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg &raquo;</TD></TR><TR><TD CLASS="quote">don't know bout the original guy who posted, but I was planned on using oem pistons w/ the pressed wrist pins...</TD></TR></TABLE>
ItRsPoOn8
Mar 31, 2007 06:40 AM
94IntegraLs04
21
Dec 8, 2006 03:59 PM
watsvtecEK
Feb 15, 2006 07:37 AM
egvtec
Dec 12, 2005 03:49 PM
turbohf
May 11, 2004 06:30 AM
