Anti-Freeze or Water
Old Sep 13, 2001 | 09:52 AM
Turbo00's Avatar
New User
Default Anti-Freeze or Water
im hearing that some people are saying that running water and water wetter is better then running anit-freeze? can anyone give me some insight on this
Old Sep 13, 2001 | 10:10 AM
Spade's Avatar
Default Re: Anti-Freeze or Water (Turbo00)
you are supposed to run a 50-50 soulution but, depends if it gets cold, if you don't live in a place where the temp drops to freezing then....you can go strait water, are you going to notice anything....NOPE. Water is cheap that is why you do it. Besides, Hondas stay so cool anyway it isn't a problem.
Old Sep 13, 2001 | 06:31 PM
R6Boy69's Avatar
Default Re: Anti-Freeze or Water (Spade)
its always good to add a little bit of antifreeze for its anti-corrosion capabilities.
Old Sep 13, 2001 | 07:17 PM
Edwin's Avatar
Straight Distilled Water and Water Wetter if you race. It will give you a very cool mix.
For street driving 50/50 Water:Coolant is sufficient.
Old Sep 13, 2001 | 07:21 PM
ThePunk's Avatar
Default Re: Anti-Freeze or Water (crXBoy69)
Water wetter and pure water is best...(If you live in areas that freeze or get close to freezing don't go without anti-freeze)
And I quote:
"The convection coefficient of liquids in a tube is a complicated relationship between the thermal conductivity, viscosity of the liquid, and the tube diameter which determines the amount of turbulent flow. Since 50/50 glycol solution has about 4 times the viscosity and only 70% of the thermal conductivity of water, the thermal convection coefficient for a 50/50 glycol solution is approximately 50% of the coefficient for water. Water in the cooling system is capable of transferring twice as much heat out of the same system as compared to a 50/50 glycol coolant and water solution. In order for a 50/50 glycol mixture to reject as much heat as water (amount of heat rejected is independent of the coolant), the temperature differentials at the heat transfer surface must be twice as great, which means higher cylinder head temperatures. "
See for yourself here:
http://www.redlineoil.com/products.htm
Old Sep 13, 2001 | 11:06 PM
Dravis's Avatar
New User
hehe I love this board...every time someone has a simple question, we get answers in science boyee language : )
Cept...they make sense, and are useful, so thanks dood : )
I ran 75% water, 25% antifreeze in my car, in Seattle weather (freezing during the winter)
And when it hit 110...or I drag raced...I never heated up, and never experienced detonation due to high cylinder head/block temps...
Hyaboosta
Jul 21, 2006 05:01 AM
idriveadelsol7
Audio / Security / Video
Apr 10, 2006 12:30 AM
Jared
Aug 15, 2005 08:06 AM
