thoughts on greddy tyrpe r bov
Type R are for high boost application, it does have a larger valve diameter but still uses a push valve system. They sounded like a chirping bird..pretty mean sounding...
stan
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torr »</TD></TR><TR><TD CLASS="quote">are the type r's prone to leaks as their counterpart the type s</TD></TR></TABLE>
im jumping on this new bandwagon, WHOS WITH ME
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin »</TD></TR><TR><TD CLASS="quote">
im jumping on this new bandwagon, WHOS WITH ME</TD></TR></TABLE>
--- raise's hand, shouting me me me me me me, pick me
type s leaking? ive come in personal contact w/ probably atleast 15 cars using the greddy type s, and not one leaked, i think u probably had urs or whoevers set wrong.
The Greddy Type R spring is pretty stiff and will cause a lot of compressor surge at lower boost levels. It tends to only open up when there is a lot pressure in the piping. Go with a ssbov from HKS or a type S if you are only going to be running 7psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lsboost »</TD></TR><TR><TD CLASS="quote">so will the R work for low boost? (7psi)?? I have heard both ways yes, and no....</TD></TR></TABLE>
I've seen this bov work great on a supra running 7lbs of boost during break-in.
Mase - I had a type S set stiff and once I started to pass 16 psi it would leak...
it made a weird woosh noise (like a charge pipe blowing off) and boost would drop, then it would stop and boost climbed back up like normal, and then it would repeat.. took me a while to figure it out... I guess the piston was just getting pushed open...
it did work good for lower boost
blinx9900
Feb 7, 2008 09:09 PM
