Turbo Oil Feed Line. (Not SS) ok?
Old Nov 21, 2003 | 04:23 AM
Talon12bp's Avatar
Default Turbo Oil Feed Line. (Not SS) ok?
I have everyone at this shop telling me that if my engine doesn't produce more than 50 to 100 PSI then im not going to need a super high pressure rated hose.
They said i can save money and go with a 300 PSI hose, and use the fittings as normal to connect the hose. but use clamps instead of threads. They say they've done it for a long time. even on turbo cars.
Will a 300 PSI pressure line work for my oil feed to the turbo?
I know its not as good as a SS, but will it most likely work for my application?
Thanks
Old Nov 21, 2003 | 04:45 AM
baddassduramax's Avatar
Default Re: Turbo Oil Feed Line. (Not SS) ok? (Talon12bp)
well you do not have 300psi of oil pressure or i hope not, turbo would be shot. the clamps should work fine, i know some people that do that and they havent had any problems. personally i like to use the threaded ends for the added protection, but thats just me
Old Nov 21, 2003 | 05:11 AM
Talon12bp's Avatar
Default Re: Turbo Oil Feed Line. (civicb18)
bump
Old Nov 21, 2003 | 05:40 AM
Overblown-Teg's Avatar
Default Re: Turbo Oil Feed Line. (Talon12bp)
yeah you can. Most use braided line for two reasons.. Bling and heat resistance.
Old Nov 21, 2003 | 06:29 AM
Flamenco-T's Avatar
Default Re: Turbo Oil Feed Line. (Overblown-Teg)
you should be fine...as long as the line aren't too big to send too much oil volume to the turbo...
3/16 is an ideal size..
stan
Old Nov 21, 2003 | 06:32 AM
Muckman's Avatar
Moderator in Chief
I choose to buy Stans oil return kit instead of installing the oil return joke included with the revhard kit. Using a regular hose and hose clamps seems more likely to be problematic with leaking. Especially inches away from the downpipe. Oil is not something you mess with.
Old Nov 21, 2003 | 09:00 AM
quikB18B's Avatar
Default Re: Turbo Oil Feed Line. (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote"> Oil is not something you mess with.</TD></TR></TABLE>
Oil does wonders as well as disasters, I woudl get the SS just for apiece of mind, but im just **** like that.
Old Nov 21, 2003 | 10:00 AM
4U2NV's Avatar
Default Re: Turbo Oil Feed Line. (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">
Oil does wonders as well as disasters, I woudl get the SS just for apiece of mind, but im just **** like that.</TD></TR></TABLE>
Plus enginebay temps are pretty high, wouldn't wanna take the risk of melting it...
Old Nov 21, 2003 | 10:46 AM
99B16Si's Avatar
Default Re: Turbo Oil Feed Line. (4U2NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">
Plus enginebay temps are pretty high, wouldn't wanna take the risk of melting it...</TD></TR></TABLE>
what he said. thats the main reason for SS. the feed sits really close to the manifold and turbing housing which could easily melt it and destroy your entire motor/ turbo if u dont notice it
Old Nov 21, 2003 | 11:09 AM
Talon12bp's Avatar
I already bought the hose, and all, and i guess SS, would be safer around higher temp areas, but i am wondering if i route the feed line around the exhaust the best i can, and maybe heat wrap the hose in that area, i should be fine right?
Thanks,
Old Nov 22, 2003 | 02:05 PM
99B16Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Talon12bp &raquo;</TD></TR><TR><TD CLASS="quote">I already bought the hose, and all, and i guess SS, would be safer around higher temp areas, but i am wondering if i route the feed line around the exhaust the best i can, and maybe heat wrap the hose in that area, i should be fine right?
Thanks,</TD></TR></TABLE>
pretty much, but i just wouldnt risk my turbo and whole motor for a $20 piece of line
Old Nov 27, 2003 | 07:21 AM
Flamenco-T's Avatar
Default Re: Turbo Oil Feed Line. (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">
pretty much, but i just wouldnt risk my turbo and whole motor for a $20 piece of line</TD></TR></TABLE>
there you go...you've spent so much money on your car, don't ruin it for $ 20 piece of line....You should already have all the fitting I can sell you a bare stainless braided lines for $ 25 with -3Female hose ends on both ends..
If you need to work out details about the lines, just let me know, I don;t mind sending the line to you and work out details of payment later, I just don't want you to ruin everything for $20 piece of rubber line, while another $ 5 you can have a peace of mind of stainless braided line..
stan
Old Nov 27, 2003 | 07:45 AM
int3gra's Avatar
Default Re: Turbo Oil Feed Line. (Flamenco-T)
now THAT is service
WagOvan Man
Mar 12, 2006 07:56 PM
tgreaves
Dec 29, 2003 11:42 AM
JDMCRX
Aug 22, 2003 08:14 AM
karmannghia
Jan 13, 2002 07:16 PM
