91 Accord EX door lock trouble
I recently had a keyless entry alarm added,ever since I have had problems w/ the locks.Sometimes one unlocks and the other doesn't and etc. etc.Sometimes everything is just fine.Are these symptoms of a failing actuator?Or did my alarm installer cause this problem?Help please!
does the main lock/unlock switch on the door panel itself do the same problem? if it does, then the installer is not at fault. the actuator and/or wiring is faulty. if not, then go back to the installer to have the problem fixed. good luck with this. i have a 92 and i know our door locks, among other things, are old and are more susceptible to disfunction.
danielw2081
Jan 19, 2018 03:29 PM
Nicefeet
Apr 13, 2011 09:15 PM
superhatchbackbros
Aug 30, 2005 05:17 PM
