how does a throwout bearing work?
Old Nov 20, 2003 | 08:51 PM
SiR HatchAlot's Avatar
Default how does a throwout bearing work?
this is the 3rd t/o bearing on the 3rd car ive owned that is making that grinding sound
how does it wear down ?
i got NO noise when the clutch pedal is pressed to the floor or just driving.
i get that noise only from letting the clutch out from a standstill (like when the light turns green) until im fully off the clutch pedal.
know what i mean?
hanks alot.. im not looking forward to getting back under my car either.
Modified by sirhatchalot5 at 6:40 AM 11/21/2003
Old Nov 20, 2003 | 09:25 PM
BauleyCivic's Avatar
Risky Business
Default Re: how does a throwout bearing work? (sirhatchalot5)
What grinding sound? The grinding sound that goes away when you press in the clutch, but when the clutch is up the engine rattles and when you get going it gets even louder? Thats the input shaft bearing. I'll explain both.
The input shaft bearing is here:
It holds the mainshaft in place. It can go bad by violently engaging the clutch repeatedly (like I do), or just go bad over time from wear from the mainshaft.
Not sure about the throwout bearing, but heres my educated guess. It is the bearing on the clutch side of the mainshaft that slides the clutch on and off of the flywheel. When the slave cylinder presses onto the clutch fork, the bearing pushes on the back of the pressure plate which disengages the clutch. It wears again by violent or repeated engagement of the clutch...which is bound to happen over time.
Old Nov 20, 2003 | 09:31 PM
MaxSterling's Avatar
Default Re: how does a throwout bearing work? (BauleyCivic)
bearing allow you to move clutch in and out while shaft is still spinning within the clutch center. a bad bearing will squeal when ever you depress clutch
Old Nov 20, 2003 | 09:33 PM
when i let off (disengage) the clutch as i give it gas, it makes a swishing/grinding noise
Old Nov 20, 2003 | 09:34 PM
Risky Business
Default Re: how does a throwout bearing work? (RoyFokker)
The input shaft bearing clanks when the clutch is NOT depressed. What happens is when you engage the clutch the mainshaft stops spinning, and so the noise stops. If the noise happens WHEN you press the clutch in, then it is a bad TOB.
Old Nov 20, 2003 | 09:35 PM
Risky Business
Default Re: (sirhatchalot5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirhatchalot5 &raquo;</TD></TR><TR><TD CLASS="quote">when i let off (disengage) the clutch as i give it gas, it makes a swishing/grinding noise</TD></TR></TABLE>
Input Shaft Bearing.
https://honda-tech.com/zerothread?id=590820
https://honda-tech.com/zerothread?id=596873
Old Nov 20, 2003 | 09:37 PM
i got NO noise when the clutch pedal is pressed or driving.
i get that noise only from letting the clutch out from a standstill until im fully off the clutch pedal.
know what i mean?
Old Nov 20, 2003 | 10:20 PM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirhatchalot5 &raquo;</TD></TR><TR><TD CLASS="quote">i got NO noise when the clutch pedal is pressed or driving.
know what i mean?</TD></TR></TABLE>
hmmm...now thats starting to sound like a TOB. PM Mista Bone
black96
29
Jan 3, 2016 08:34 PM
Solstic
Jun 13, 2012 11:34 AM
wessieball
Feb 25, 2009 12:44 PM
04civicex84
Honda Civic (2001 - 2005)
Nov 13, 2008 02:44 PM
Cereal_Killer
20
Nov 2, 2002 10:00 AM
