B16 into my ef. Cant get the Place Racing rear mount to line up.
Old Sep 13, 2001 | 05:49 AM
4G-CIVIC's Avatar
New User
Default B16 into my ef. Cant get the Place Racing rear mount to line up.
I finally started to put my b16 in and realized the rear mount that bolts onto the car in the rear is 2" or so lower than the 89-91 SIR rear mounting bracket that is coming off of my engine.
Someone said I need the 90-93 teg rear bracket while someone else said that the SIR and 90-93 Teg bracket are the same????
What to do????
Old Sep 13, 2001 | 06:29 AM
Stinkalope's Avatar
New User
Default Re: B16 into my ef. Cant get the Place Racing rear mount to line up. (4G-CIVIC)
I have a HCP kit but same setup. You need the 90-93 integra rear trans. bracket. I help put a b16 in a buddy's hatch and had the same problem. I had to order mine from Acura because nobody in town had it. I forgot exactly what it cost, I think it was like 70 or something. Anymore problems, ask away......
Old Sep 14, 2001 | 04:07 PM
4G-CIVIC's Avatar
New User
Default Re: B16 into my ef. Cant get the Place Racing rear mount to line up. (Stinkalope)
JOE at Hasport said the 90-93 teg was same as SIR. So... What is the problem, thats what I cant figure out.
Old Sep 14, 2001 | 04:51 PM
JDM_DOHC_SiR's Avatar
New User
Joe is correct ...the P/N#s are the same over here in Japan...but you say that the mount hole is about 2inches lower..???hhhhmmmmrm..do you have the side mounts on and bolted in.?? See if you are not hitting any thing or make sure that nothing is the way of the mount..?? Also try pushing down on the intake manifold to see if you can get the bolt started..
Mekk82
Apr 17, 2013 11:32 AM
aaronhume
Feb 11, 2005 08:45 AM
slowem1si
Jun 19, 2004 12:12 PM
Dainbramage
May 23, 2004 05:08 PM
joestud
Feb 15, 2003 04:44 AM
