Sunroof sticking how do I clean tracks?
Old Nov 20, 2003 | 06:58 PM
Ramocheese's Avatar
Default Sunroof sticking how do I clean tracks?
Hey everyone, my sunroof seems to skip a little bit when opening and was wondering if there is any easy ways to clean the tracks?
Old Nov 20, 2003 | 07:03 PM
fenix77's Avatar
Default Re: Sunroof sticking how do I clean tracks? (Ramocheese)
I just added some silicone grease to the tracks and it fixed that problem up
Old Nov 20, 2003 | 07:40 PM
VTi NA's Avatar
Wipe any dirt, dust etc from the rails, followed by a liberal application of lithium grease. Should do the trick
Old Nov 20, 2003 | 07:48 PM
jimmydc2's Avatar
cleaning the rails and using silicone lube worked on my car initially. but now my problem is the plastic that slides on the rail, so i would have to replace it. your car is 1997 right? cleaning and using silicone should be fine for now.!
Old Nov 20, 2003 | 07:57 PM
P1mpSlap's Avatar
Clean the tracks with alcohol first then apply lithum grease
Do not use any solvent to clean it. It'll gunk up and make it worse.
Old Nov 20, 2003 | 11:03 PM
Must be VTEC's Avatar
CLEAN FOOL!!!!!!!!!!! You know how to clean??????? O yeah ur car is slow by the way!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
