96-00 Civic HEADLIGHT BEAM adjustment? *HID*
okay, I looked at the thread titled "The HID Thread", and I didn't find what I was looking for, My Ctr headlights point the bulbs to the left, I need to adjust it, I've heard of tightening/loosening the screws on the back of the headlamp assemblies, but It doesn't budge, Let me know how you guys do it. TIA
if you need to adjust - left to right or vice-versa use the adjustment screw/**** towards the center (grill) on the back of the headlamp - you will need to adjust it many rotations as it only moves it a slight bit...I would would cover up the other headlamp so you get a clear picture of the beam of light you are trying to adjust - also make sure the headlamp appears to be installed "straight" compare to the other
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill_take_one »</TD></TR><TR><TD CLASS="quote">Hmmm, your headlight adjustment screws dont even move?
you could be screwed! (haha)
LoL
You don't use screws to adjust your headlights.. There are bolts that you have to turn.. I think it's towards the center of the front. You'll have to play with it to get the beam where you want it.
LoL
They're not bolts either. They're more like little gears that you have to turn with a philips head screwdriver, but I think he tried that already.
Check to see if the bulb is installed right. Wiggle it around a little to see if you can lock it in place. Otherwise, those headlight adjustment ***** are all you have left.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDEM1 »</TD></TR><TR><TD CLASS="quote">how do you make those gears turn?, seems like they dont budge
need help..
</TD></TR></TABLE>need help..
jdmezbuy
Mar 21, 2008 08:41 PM
