JDM corner lights...??
They will work, you mean the jdm clear corners, right? Keep in mind though, they only have one bulb, the us version has 2. Ryan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryant »</TD></TR><TR><TD CLASS="quote">They work. just needs a little modification to get them perfect.</TD></TR></TABLE>
Say wuuut?????
Say wuuut?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StickyGreen »</TD></TR><TR><TD CLASS="quote">
please provide some information to help us out. =D</TD></TR></TABLE>
sorry hahaha
well 88-89 headlight have NO bracket insert for the corners as the corners uses SCREW to stay mounted.
90-91 headlight have a bracket for the corners to be inserted as well as two little bracket on the fender for more secure holding, and uses ONE screw above the bracket of the headlight.
88-89 headlight are a tad off but still works for all 88-91 with some mods. same goes with 90-91 headlights.
and to some who ask if jdm corners fit on usdm fenders, YES. they fit. no mods needed. i have USDM fenders with JDM stanley corner lens . fit perfectly. unless you have the 88-89 fenders den it will require some modding. but not much.
sorry hahaha
aloha,
i have a 91 Civic Si and purchased a set of brand new oem Si-R clear corners for my usdm front end.
the Si-R corners doesn't seem to fit to well with my usdm headlights. i went back and test fitted the stock corner light and it fits perfect.
how do you "mod" the Si-R units to fit properly with the usdm front lights?
this is for a 90-91 Civic.
thanks
thanks
^ do you have any pictures of how it doesnt fit????? im pretty sure it should fit in there nicely.....maybe im wrong about the civics. crx i kno for sure.
B2FiNiTY
Feb 24, 2004 08:34 PM
