2004 NHRA rule revisions HERE
Old Nov 20, 2003 | 03:01 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default 2004 NHRA rule revisions HERE
FOR IMMEDIATE RELEASE
Contact: NHRA Communications Dept., (626) 914-4761
NHRA ANNOUNCES RULE CHANGES FOR
2004 NHRA SUMMIT SPORT COMPACT DRAG RACING SERIES
GLENDORA, Calif. (Nov. 20, 2003) - NHRA officials announced today rule changes for its growing 2004 NHRA Summit Sport Compact Drag Racing Series. The NHRA Summit Sport Compact Drag Racing Series consists of 10 events in 2004 and will feature the biggest names in the sport compact drag racing scene.
"The NHRA Summit Sport Compact Drag Racing Series saw tremendous growth and first-class competition in 2003," said Jim Skelly, racing competition director, NHRA. "Next year's rule changes are designed to further stimulate competition, and promote consistency among the different combinations within each class, in 2004 and beyond."
Among the rule changes for 2004 include engine displacement, turbocharger and body guidelines. The complete 2004 NHRA Sport Compact Rulebook will be available online within the next few weeks.
Entering its fourth season in 2004, the NHRA Summit Sport Compact Drag Racing Series has seen steady growth in the number of competitors participating in the series, along with vast improvements in consistency and on-track performance from the race teams. The series, which has seen increases in participation from both traditional and non-traditional sponsors, also has experienced an increase in fan attendance each season, along with continued expansion in the lifestyle arena.
The NHRA, with headquarters in Glendora, Calif., is the premier sanctioning body for sport compact drag racing. It presents the 10-race, $2.1 million NHRA Summit Sport Compact Drag Racing Series at nine tracks across the country from March-October. The series features the largest guaranteed sport compact event purse of more than $26,000 paid out per event. In addition, the series offers a year-end championship fund of $144,000, along with more than $1.7 million in contingency payouts. The series is highlighted by its five championship classes (Pro RWD, Pro FWD, Modified, Turbo Magazine Hot Rod and Honda Tuning All Motor). For more information, please visit http://www.nhrasportcompact.com.
The following rule changes will be implemented by NHRA for the 2004 NHRA Summit Sport Compact Series:
ALL MOTOR:
New Minimum Weights
FWD 4 cyl.
Up to 2.20 liter (134.25 ci) 1,675 pounds
2.21 to 2.4 liter (134.26 ci to 146.50 ci) 1,700 pounds
2.41 to 2.6 liter (146.51 ci to 158.50 ci) 1,725 pounds
2.6 max displacement, regardless of weight
Full tube chassis +75 pounds
Back half chassis +25 pounds*
*A back half car complies with ALL unibody rules except for missing OEM rear strut towers. All other non-compliant vehicles default to Full tube chassis penalty.
RWD 2 rotor 1,900 pounds
RWD 4 cyl:
2.0 liter (122.25 ci) & less 1,825 pounds
2.01 to 2.2 (122.26 ci to 134.25 ci) 1,850 pounds
2.21 to 2.4 (134.26 ci to 146.50 ci) 1,875 pounds
2.41 to 2.6 (146.51 ci to 158.50 ci) 1,900 pounds
2.6 max displacement, regardless of weight.
VW air cooled.
"Type 1" or "waterboxer", cast magnesium or cast aluminum case permitted. NHRA accepted aftermarket heads permitted. Accepted aftermarket heads are:
910 Pro Series AutoCraft
SHO Performance Technology
Max displacement 2.6 liter (158.50 ci) 1,725 pounds
Aftermarket transmission
+150 pounds all cars
Chassis:
Center-driver position prohibited. Driver must be located completely to the left or right of vehicle centerline.
Body
Body must be on NHRA Accepted Body list. Pickup and SUV bodies prohibited.
PRO RWD:
4 cylinder/2 rotor 2,000 pounds 1 or 2 power adders
Maximum displacement 2.8 liter (170.75 ci)
3 rotor (no change) 2,200 pounds 1 or 2 power adders
6 cylinder
3.5 liter (213.50 ci) max 2,350 pounds 1 power adder
3.5 liter (213.50 ci) max 2,450 pounds 2 power adders
Max turbo on 6 cylinder = 91.5 mm single, 72 mm twins, measured as follows:
Single Turbocharger - Single turbochargers are permitted with the following requirements: 1) Turbocharger must be of conventional impeller and housing design and type. 2) Turbocharger is limited to a maximum size of 3.602" (91.49mm) - inducer wheel diameter at the point where the leading edge of the compressor wheel meets the inlet housing. 3) Inlet housing is permitted a maximum inlet diameter of 3.673" (93.29mm) where the leading edge of the compressor wheel meets the housing. 4) All air entering the turbocharger must pass through the turbocharger inlet. Injection of any liquid, gas or any other substance into the inlet or exhaust housing is prohibited. Turbocharger compressor wheel must be constructed of cast or billet aluminum. Exotic material wheels prohibited.
Twin Turbochargers - Dual (2) turbochargers are permitted with the following requirements: 1) Each Turbocharger must be of conventional impeller and housing design and type. 2) Each Turbocharger is limited to a maximum size of 2.834" (71.98mm) - inducer wheel diameter at the point where the leading edge of the compressor wheel meets the inlet housing. 3) Inlet housing of each turbocharger is permitted a maximum inlet diameter of 2.905" (73.78mm) where the leading edge of the compressor wheel meets the housing. 4) All air entering the turbocharger(s) must pass through the turbocharger inlet. Injection of any liquid, gas or any other substance into the inlet or exhaust housing is prohibited. Each turbocharger compressor wheel must be constructed of cast or billet aluminum. Exotic material wheels prohibited.
Chassis:
Body: Body must be on Accepted Body List.
Body must be of import manufacture or domestic-labeled, joint-manufactured platform. (Examples are Chevy Cavalier, Chrysler Conquest, Chevy S-10, Dodge Colt, Dodge Neon, Dodge Stealth, Eagle Talon, Ford Focus, Ford Probe, Ford Ranger, GMC Sonoma, Mercury Cougar, Plymouth Laser, Pontiac Sunfire.) Domestic models must be NHRA accepted.
Mild customizing, chopping, channeling, sectioning permitted, but must retain full-size, full-bodied appearance, with minimum 2 functional doors. Doors must open and close from inside and outside. OEM glass may be replaced with Lexan or other shatterproof material, minimum thickness 1/8-inch. Lightweight replacement panels permitted. Body must be full scale (7/8-, 3/4-scale, etc. prohibited). Final approval rests with NHRA. NHRA will monitor size, shape, and mounting of spoilers and/or wings; final approval rests with NHRA. Maximum front overhang 45-inches, measured from front of car to center of spindle. In the interest of maintaining "stock bodied appearances" of Pro RWD vehicles, NHRA is currently evaluating body dimension guidelines and methods of enforcement. It is strongly advised that any new Pro RWD vehicles under construction should be held as close to stock dimensions as possible. Final Approval rests with NHRA. Front ends may be lengthened to establish 45-inch maximum overhang measurement. Body must appear on Accepted Body List.
MODIFIED:
Minimum Weights
RWD or AWD 2 rotor (1 or 2 power adders) 2,000 pounds
RWD or AWD 4 cylinder, up to 2.8 liter (170.75 ci) (1 or 2 power adders) 2,100 pounds
RWD or AWD 6 cylinder, up to 3.5 liter (213.50 ci) (1 power adder max) 2,700 pounds
Non-OEM floor: add 100 pounds.
Max turbo size on 6 cylinder = 78 mm single, 61 mm twins, measured as follows:
Single Turbocharger - Single turbochargers are permitted with the following requirements: 1) Turbocharger must be of conventional impeller and housing design and type. 2) Turbocharger is limited to a maximum size of 3.070" (77.98mm) - inducer wheel diameter at the point where the leading edge of the compressor wheel meets the inlet housing. 3) Inlet housing is permitted a maximum inlet diameter of 3.141" (79.78mm) where the leading edge of the compressor wheel meets the housing. 4) All air entering the turbocharger must pass through the turbocharger inlet. Injection of any liquid, gas or any other substance into the inlet or exhaust housing is prohibited. Turbocharger compressor wheel must be constructed of cast or billet aluminum. Exotic material wheels prohibited.
Twin Turbochargers - Dual (2) turbochargers are permitted with the following requirements: 1) Each Turbocharger must be of conventional impeller and housing design and type. 2) Each Turbocharger is limited to a maximum size of 2.401" (60.98mm) - inducer wheel diameter at the point where the leading edge of the compressor wheel meets the inlet housing. 3) Inlet housing of each turbocharger is permitted a maximum inlet diameter of 2.472" (62.78mm) where the leading edge of the compressor wheel meets the housing. 4) All air entering the turbocharger(s) must pass through the turbocharger inlet. Injection of any liquid, gas or any other substance into the inlet or exhaust housing is prohibited. Each turbocharger compressor wheel must be constructed of cast or billet aluminum. Exotic material wheels prohibited.
Transmission:
Air shifters prohibited.
Chassis:
Body:
Body must be on Accepted Body List. Pickup or SUV prohibited.
HOT ROD:
Maximum displacement = 2.5 liter (152.50 ci)
Maximum turbo size = 78 mm, single configuration only, measured as follows:
Chassis:
Body:
PRO FWD:
Engine:
Maximum displacement 2.8 liter (170.75 ci).
Maximum one (1) turbocharger permitted. No size restriction at this time.
Chassis:
Tires:
DOT or racing slicks permitted with a maximum width of 11.5 inches and maximum height of 31.0 inches. Maximum rollout on drive tires 99 inches.
Body:
Any FWD, 4-cylinder automobile, import or domestic, permitted. OEM RWD or AWD may not be converted to FWD. Mild customizing, body kits, and chopped roofs permitted, but must retain full-bodied appearance, with minimum 2 functional doors. Doors must open and close from inside and outside. OEM glass may be replaced with Lexan or other shatterproof material, minimum thickness 1/8-inch. Body parts may be replaced with lightweight replacement panels. One-piece, lift-off front ends permitted. Maximum front overhang 45 inches, measured from front of car to center of front axle. In the interest of maintaining "stock bodied appearances" of Pro FWD vehicles, NHRA is currently evaluating body dimension guidelines and methods of enforcement. It is strongly advised that any new Pro FWD vehicles under construction should be held as close to stock dimensions as possible. In particular, oversized "bulges" or "humps" on front fenders are prohibited. Final Approval rests with NHRA. Front ends may be lengthened to establish 45-inch maximum overhang measurement. Body must appear on Accepted Body List. (To be published.)
SPORT FWD:
Tires: DOT or racing slicks permitted with a maximum width of 10.5 inches and maximum height of 26.0 inches.
Old Nov 20, 2003 | 03:11 PM
Jared's Avatar
Default Re: 2004 NHRA rule revisions HERE (SIXTYdashONE)
haha, i just posted this about 10 minutes ago.
Old Nov 20, 2003 | 03:29 PM
dimebag9's Avatar
Postwhore
But yeah the rules look alot better. Everyones getting crazier setups so it was definatly time for a rule change.
Austin's Avatar
Very nice...looks like they're trying to make it a more level playing field for everyone. Should be an interesting year...
Old Nov 20, 2003 | 04:07 PM
RacerStev's Avatar
Default Re: (Austin)
Funny, Sport FWD can run a larger turbo then Hot Rod, not that anyone will
26 by 10.5 is a pretty big tire too, guess it's time to get out the sawz all!
Steve
Old Nov 20, 2003 | 04:17 PM
HT's Biggest Loser
Default Re: (RacerStev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerStev &raquo;</TD></TR><TR><TD CLASS="quote">Funny, Sport FWD can run a larger turbo then Hot Rod, not that anyone will </TD></TR></TABLE>
Says who?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerStev &raquo;</TD></TR><TR><TD CLASS="quote">26 by 10.5 is a pretty big tire too, guess it's time to get out the sawz all! Steve </TD></TR></TABLE>
We still arent allowed to cut anything in the wheelwell or anything, right?
Old Nov 20, 2003 | 04:20 PM
Jared's Avatar
Default Re: (SIXTYdashONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">
We still arent allowed to cut anything in the wheelwell or anything, right?</TD></TR></TABLE>
Pretty sure they OK'd fender cutting as long as it follows stock lines, people were complaining about aftermarket fenders being ok, but cutting being illegal.
Old Nov 20, 2003 | 04:35 PM
Fabman's Avatar
Lierley Fab
Default Re: (Jared)
norran is **** the car canot race nhra tony let me now what you are going to do
Old Nov 20, 2003 | 04:40 PM
Jared's Avatar
Default Re: (fabman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabman &raquo;</TD></TR><TR><TD CLASS="quote">norran is **** the car canot race nhra tony let me now what you are going to do</TD></TR></TABLE>
what rule is keeping you from racing?
Old Nov 20, 2003 | 04:44 PM
dimebag9's Avatar
Modified by dimebag9 at 2:15 AM 11/21/2003
Old Nov 20, 2003 | 04:56 PM
Scott Mohler's Avatar
Looks to me the Bugs are making out in All Motor. 2.6L RWD @ 1725 lbs?? -75lbs over 2003
Scheepers/Padilla can take off 100 lbs next year. They took 50 away from the RWD rotories and 50 away from the aftermarket trannies.
Ahh well ........
Modified by Scott Mohler at 2:10 AM 11/21/2003
Old Nov 20, 2003 | 05:07 PM
tony1's Avatar
We're going to run the new car at NOPI and the old one at NHRA. NOPI has approved it and doesn't have a restriction on tire size. Think about it, we plan to make about 1400hp. Now, would you ever consider putting a 31 x 11 tire on a pro rwd car with 1400hp? We have the disadvantage of weight transfer, a big disadvantage, and they want us to run a smaller tire than a rwd car? If anything, we should run a bigger tire!
Old Nov 20, 2003 | 05:10 PM
Z10ROB's Avatar
Its been a good season for us ( the people we sponsor ) lets keep it going!
Old Nov 20, 2003 | 05:15 PM
Austin's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">We're going to run the new car at NOPI and the old one at NHRA. NOPI has approved it and doesn't have a restriction on tire size. Think about it, we plan to make about 1400hp. Now, would you ever consider putting a 31 x 11 tire on a pro rwd car with 1400hp? We have the disadvantage of weight transfer, a big disadvantage, and they want us to run a smaller tire than a rwd car? If anything, we should run a bigger tire! </TD></TR></TABLE>
If I read this correctly the PRO-RWD does not have a tire rule, whereas the PRD-FWD does...?
What size tire were you looking to run Tony?
Old Nov 20, 2003 | 05:27 PM
Taco Sauce's Avatar
Default Re: (tony1)
one word... SICK
Old Nov 20, 2003 | 05:45 PM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">
What size tire were you looking to run Tony?</TD></TR></TABLE>
Correct, we are going to run a 33 x 16, the same as most pro rwd cars run...
Old Nov 20, 2003 | 05:47 PM
boostedh22a's Avatar
Default Re: (tony1)
holy ****!!!! What is it, a FWD 69 Camaro, powered by a alcohol injected big block.
Old Nov 20, 2003 | 06:12 PM
Bisimoto's Avatar
Default Re: (boostedh22a)
Why is the Honda CRX not on the approved body list for 2004+? Should I invest in an accord?
Old Nov 20, 2003 | 06:13 PM
Gmedalion's Avatar
Default Re: (tony1)
Tony, u guys still building the car for the driver to be placed in the center?
Old Nov 20, 2003 | 06:16 PM
Default Re: (Bisimoto)
accords rock man!!!!
Old Nov 20, 2003 | 06:34 PM
Adam F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bisimoto &raquo;</TD></TR><TR><TD CLASS="quote">Why is the Honda CRX not on the approved body list for 2004+? Should I invest in an accord?</TD></TR></TABLE>
Maybe they consider it a Civic CRX?
Old Nov 20, 2003 | 06:35 PM
1fstcorrado's Avatar
Default Re: (Gmedalion)
that is gonna be the only way to see over them monsters.
Old Nov 20, 2003 | 06:49 PM
poorguy's Avatar
Default Re: (1fstcorrado)
why are air shifted trannies prohibited in modified? i've got a liberty airshifted tranny that's completely useless now.
Old Nov 20, 2003 | 07:12 PM
tony1's Avatar
No, another rule change that set us back a little...
Old Nov 20, 2003 | 07:16 PM
Fabman's Avatar
Lierley Fab
Default Re: (tony1)
that sucks
