Is transmission swap realiable? Any one got any problems?
Old Nov 20, 2003 | 02:47 PM
brian2903's Avatar
Default Is transmission swap realiable? Any one got any problems?
I'm going to do auto to 5 speed swap, but some of my friends said it is not realiable after it. However, they didn't say how non-realiable is that. So, do anyone knows more about it? or even you are facing the problems with this swap?
Old Nov 20, 2003 | 05:37 PM
carolinaACCORD's Avatar
Default Re: Is transmission swap realiable? Any one got any problems? (brian2903)
As long as everything is done RIGHTand the parts are GOOD, it'll be just as reliable as an original manual tranny car.
Now if you do it half-assed (i.e., hardware not torqued correctly, clearances and tolerances off, and general redneck-drunkenness-throw-together), it's gonna be crap.
"You get out what you put in". Remember that in every aspect of life.
Old Nov 20, 2003 | 06:40 PM
whoa its len 2's Avatar
You're going to be using OEM parts and you're going to install everything to OEM spec. Cant get any more reliable as OEM.
Old Nov 21, 2003 | 06:10 AM
KGAccord's Avatar
Default Re: Is transmission swap realiable? Any one got any problems? (whoaitslen2)
the only issues which may lie would be with attaching the clutch pedal to the firewall and wiring up the reverse lights. some shops/people can **** those things up. other than that like already mentioned your just using OEM parts, but if your using used stuff you could get some bad stuff.
Rydo
Audio / Security / Video
May 26, 2011 08:05 PM
Oversoulx2
Nov 15, 2007 01:12 PM
Phake
Oct 27, 2004 11:45 AM
koy
Jun 26, 2002 07:59 PM
