installing air/fuel gauge
Old Nov 20, 2003 | 01:26 PM
THE94GSR's Avatar
Default installing air/fuel gauge
well tomorrow im going to install the air/fuel gauge in my car i was wounding which wire do i splice on the o 2 sensor is it the green one or the white one... by the way its going on a 94 gsr
Old Nov 20, 2003 | 01:27 PM
neo1z's Avatar
Default Re: installing air/fuel gauge (THE94GSR)
White.
Old Nov 20, 2003 | 04:11 PM
.honda.'s Avatar
you could do that but i think it would be easier to go through the ecu...thats how i hooked up mine and everything went well....
Old Nov 20, 2003 | 04:41 PM
Steve04SVT's Avatar
Default Re: installing air/fuel gauge ([DC2])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [DC2 &raquo;</TD></TR><TR><TD CLASS="quote">]you could do that but i think it would be easier to go through the ecu...thats how i hooked up mine and everything went well.... </TD></TR></TABLE>
Yeah do that. I've always done that whenever I would install A/F guages. It is a lot easier to run the wires to the ECU, than to the O2 sensor.
Old Nov 20, 2003 | 04:51 PM
Dra6on45's Avatar
when running to the ecu, would you still need a wideband O2 sensor for it to read effectively?
Old Nov 20, 2003 | 08:03 PM
96dc2's Avatar
Default Re: (Dra6on45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dra6on45 &raquo;</TD></TR><TR><TD CLASS="quote">when running to the ecu, would you still need a wideband O2 sensor for it to read effectively?</TD></TR></TABLE>
You'd also need a controller. PLXdevices makes a peice that will let you use a wideband setup with a narrowband guage.
preludefien
Dec 13, 2006 03:31 PM
90 Si Hatch
Dec 10, 2004 05:07 PM
JDM-97CX
Feb 24, 2004 11:54 AM
shift6th
Feb 10, 2004 04:52 PM
HarryB
Sep 19, 2002 07:30 AM
