Anywhere to get this rare "antique"?
Old Nov 20, 2003 | 12:14 PM
Hites
Guest
Posts: n/a
Default Anywhere to get this rare "antique"?
anybody know of a place to get a b17 tranny? the reason i ask is because im looking for a cable tranny with b18c-like gearing for a jrsc b18c crx im building. ive looked everyone and i cant find a single one. the b16 trannys gears are too short for my liking and the b18b trannys gears are too long (goldilocks and the 3 bears, eh? ).
Old Nov 20, 2003 | 12:27 PM
tossnupweight's Avatar
Default Re: Anywhere to get this rare "antique"? (Hites)
looked everywhere? my car has one. and to the best of my knowledge, my gears are identical to the b16 except 1st and 5th, which are actually shorter. 2nd, 3rd, 4th and final are the same.
Old Nov 20, 2003 | 03:10 PM
curt801's Avatar
search for ys1 (92 gsr tranny) hard to find is right since there wasn't a lot of the b17 made. i have one on my b17 it grinds third gear though. i might be selling it in a couple of weeks.
Old Nov 20, 2003 | 03:19 PM
mr.beeks's Avatar
Default Re: (b1788crx)
I seen one in
http://www.urbanracer.com
just search thru classifieds the guys name is dwight.
Old Nov 20, 2003 | 03:29 PM
Colin's Avatar
the b17a1 tranny is a ys1. But so is the 92-93 b18a tranny. The gearing is just different. So be aware that just because it says ys1.....it doesn't mean its a short geared one.
There are 2 downsides to the gsr ys1:
-they are hard to find cause they are rare
-they are older and usually have a lot of miles..... 3rd gear is characteristically bad with these trannies. So just assume that you'll need to be replacing at least your 3rd gear set in the near future.
It would probably be more cost effective, in the long run, to round up a ys1 case or one w/ bad gears.... for cheap. Then try to get the itr gears, cause they'll fit easily in the case (only a slight mod needs to be done). This way you'll have the itr gearing you want, it'll be basically brand new, and it may cost less than getting a ys1 and having to rebuild it. Just another option to consider.
Old Nov 20, 2003 | 03:40 PM
Colin's Avatar
a guy I know is currently selling one: http://www.g2ic.com/forums/sho...78274
as you can see they aren't exactly cheap.... even when not in perfect condition
Old Nov 20, 2003 | 04:32 PM
Hites
Guest
Posts: n/a
Default Re: (91IntegGS)
what gears are the b18a most like? the b18b or b18c?
Old Nov 20, 2003 | 04:41 PM
97itr86's Avatar
Default Re: (Hites)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hites &raquo;</TD></TR><TR><TD CLASS="quote">what gears are the b18a most like? the b18b or b18c?</TD></TR></TABLE>
B18b
Old Nov 20, 2003 | 05:10 PM
Hites
Guest
Posts: n/a
which would be better for my application? my project car will be mostly daily driven. should i get the short geared b16a tranny or the long geared b18b tranny?
Old Nov 20, 2003 | 06:06 PM
Colin's Avatar
you'll have to talk to the supercharged guys. Everything that i've heard has been..... if you go NA then you want short gears, if you go Turbo, you want longer gears. I'm not sure if that applies to superchargers as well or not.
Old Nov 20, 2003 | 07:14 PM
Default Re: Anywhere to get this rare "antique"? (91IntegGS)
it does. superchargers are only different from turbos in the way they are powered. turbo- exhaust, supercharger- engine
Old Nov 20, 2003 | 08:15 PM
Colin's Avatar
Default Re: Anywhere to get this rare "antique"? (tossnupweight)
ok, thats good to know.
I know how a turbo works, and I realize how a supercharger works. But boost levels are different, and the means by which they are powered are different..... I just didn't want to speculate with the possibility of giving wrong or unhelpful info.
Old Nov 20, 2003 | 08:25 PM
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91IntegGS &raquo;</TD></TR><TR><TD CLASS="quote">ok, thats good to know.
I know how a turbo works, and I realize how a supercharger works. But boost levels are different, and the means by which they are powered are different..... I just didn't want to speculate with the possibility of giving wrong or unhelpful info.</TD></TR></TABLE> saying that longer gears are better for boost (ie ls tranny vs. gsr) is wrong.
Old Nov 21, 2003 | 10:34 AM
Hites
Guest
Posts: n/a
Default Re: Anywhere to get this rare "antique"? (Threatcon13)
supercharger boost is relative to engine rpm since its belt driven; boost is always there and its constantly building if youre accelerating. turbo boost kicks in nearly instantaneously and is exhaust powered; wont have very much power in the lower rpms because of the long intake track and the time for the turbo to spool, but is more powerful in the mid to upper rpms (depending upon turbo size) because of the lack of parasitic drag.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote"> saying that longer gears are better for boost (ie ls tranny vs. gsr) is wrong. </TD></TR></TABLE>
then please share your recommendation with your reasoning
Old Nov 21, 2003 | 02:37 PM
Colin's Avatar
Thats why I didn't directly say that. Read my post again.....I only stated what is usually thrown around as the general rule (and I didn't mention it related to boost...only turbo) on most of the forums. And then continued to say that he needed to go talk to people who know more about superchargers than myself.
Old Nov 21, 2003 | 03:02 PM
Cramerox's Avatar
oh man i can see where this is going to lead...
Old Nov 21, 2003 | 04:03 PM
Hites
Guest
Posts: n/a
this thread better not turn into a fireball slinging debate. now, is the b18a tranny from the gen2 teg a cable tranny?
Old Nov 21, 2003 | 04:45 PM
mr.beeks's Avatar
90-93 cable...
Old Nov 21, 2003 | 06:46 PM
VSM3point5genDC4's Avatar
shorter gears means faster acceleration no matter what. longer gears are more designed for driver comfort (i.e. not haveing to shift as often)
Old Nov 22, 2003 | 01:10 AM
Colin's Avatar
yes, all 90-93 b18a1 tegs had cable trannies. Hoever they are not the same. Gearing changes a little I believe. But more importantly the casings, internals and clutch disks are different (clutches are different because the spline sizes are different). The 90-91 trannies will NOT accept the itr and other hydro gears. Whereas the ys1's (92-93's) will accept hydro internals.
crxsi8
May 13, 2006 07:08 PM
ACrite3404
Sep 21, 2005 06:56 AM
CRX-SIR
Jul 27, 2005 03:43 AM
phatgt4evr
Aug 7, 2004 09:46 PM
