My All-Motor SOHC Build-Up...2 much compression?
Z6 Head,Y8 Head Gasket, P28 ECU, Z6 Intake Manifold/Distributor, Injectors/fuel rail, OBD1 Conversion Harness
A6 Block
P29 Pistons
LS Throttle body w/ Z6 intake manifold port matched (bored 2mm)
I'm guessing ill be running over 12:1 compression. Is that too much? What are your opinions on this mini me setup?
Should I just leave out the P29 pistons? Or should I scrap the z6 head and obd0 conversion because I can get better cams for the a6 head? but then i cant use a teg tb on the intake manifold...
I can't really decide what to do...
Does anyone have this setup or close to it? I'm curious what I can run with an Si tranny on my 4th gen hatch...
A6 Block
P29 Pistons
Also, I'm just curious what I can expect in the quarter mile with all this....
A6 Block
P29 Pistons
Camshaft/Camgear- can't decide which ones?....help on this pls!
Bolt on's:
AEM cold air
DC SPorts 4-2-1 Header
Full cat-back exhaust
12lb. Flywheel
act stage 2 clutch
Magnecor wires
NGK V-Power plugs
Lightweight Crank Pulley
A6 Block
P29 Pistons
Bolt on's:
AEM cold air
12lb. Flywheel
act stage 2 clutch
Magnecor wires
NGK V-Power plugs
with that much compression form the piston, it might hinder flame travel, might wanan mill the head and block to help with compression so you can buy lower comp pistons and not hurt flame travel
That is exactly what is was thinking, the flame would have to spead a pretty arched path. I am not sure what PM6 pistons with a 1mm mill on the head would yield, but i think it would run 100 times better
Brett
Brett
