Clutch questions
Old Nov 20, 2003 | 10:29 AM
sohcvtec1995's Avatar
Default Clutch questions
ok.. here is the question. if you have (making up numbers) 5000 pound clutch/pressure plate would it be easier to push the clutch in or harder to push vs let say a 2500 pound clutch? cause i figured that the high the number the easier it is to push in since you wopuld think that the pressure plate was applying that much pressure right?
Old Nov 20, 2003 | 02:48 PM
Default Re: Clutch questions (sohcvtec1995)
anyone know the answer to this?
Old Nov 20, 2003 | 02:51 PM
EL Vap133's Avatar
The more extreme the pressure plate the harder the pedal....
Old Nov 20, 2003 | 02:52 PM
Default Re: Clutch questions (EL Vap133)
so that would be the lower the number the harder? or vica vearsa?
SuicideSlide
11
Aug 29, 2004 01:25 PM
Nextelbuddy
Jun 19, 2003 06:37 PM
