¡¡¡¡¡!!!!! Hard Core Drag Parts !!!!!¡¡¡¡¡
Old Nov 20, 2003 | 08:38 AM
Trooper's Avatar
Default Hard Core Drag Parts, Clutch Masters, TODA, APEX, Port Flow and some JDM parts TOO
1. Clutch Masters Twin Disk Used for than 5 Passes $900 obo
2. Hy-tech Side Exit $900 obo
3. 2 Clutch Masters Stage 4 Clutches with Lightened Flywheel's 400.00 obo4. Toda first Generation Cam gears. $150
5. Port Flow GSR head, Needs Machine work to combustion Chambers. RS said that they can Fix it!!!. Port Flow Valve train and Ports. 500.00 Every thing except the Distributor and VTEC solenoid
6. Apex Steel Pillow Mounts all 4 150.00
7. Vafc 150.00 Sold
8. JDM EG Climate Control 50.00
9. JDM EG Power Folding Mirror Switch 25.00
Clutch Before it was run
Clutch before instillation
My Hy-tech Header
Modified by Trooper at 10:40 AM 11/20/2003
Modified by Trooper at 4:21 PM 11/24/2003
Modified by Trooper at 10:15 AM 11/26/2003
Modified by Trooper at 3:13 AM 11/29/2003
Old Nov 20, 2003 | 08:51 AM
Trooper's Avatar
Default Re: ¡¡¡¡¡!!!!! Hard Core Drag Parts !!!!!¡¡¡¡¡ (Trooper)
Bump
Old Nov 20, 2003 | 09:19 AM
Trooper's Avatar
Bump
Old Nov 20, 2003 | 09:24 AM
Bud@Zero4Racing.com's Avatar
Bumperated!
Old Nov 20, 2003 | 09:46 AM
Trooper's Avatar
Default Re: ¡¡¡à ƒÂ‚¡Â¡!!!!! Hard Core
bump
Old Nov 20, 2003 | 10:02 AM
LODOSS's Avatar
that is one hell of a deal for the vafc.
Old Nov 20, 2003 | 10:06 AM
itr_18's Avatar
Great header, I wish I had one like this! bump
Old Nov 20, 2003 | 10:18 AM
Trooper's Avatar
Default Re: (itr_18)
Bummp
Old Nov 20, 2003 | 10:30 AM
Jowee's Avatar
Default Re: (Trooper)
NICEEEEEEEEEEEEEEEEEEEEEE header. How would that sound/fit on my ITR? Could I drive that on track days for 45 minute heats without issue?
EDIT: Can't spell when excited about cool car parts.
Old Nov 20, 2003 | 10:36 AM
Trooper's Avatar
Default Re: (ITR 98 1162)
Ha ha Spell Check is my friend also !! As for the header, It fit perfectly in my eg, cleared all coolant hoses and the radiator absolutely fine. It is a nice piece because you can run a stock bumper the exit is right under the frame rail. As far as noise, 45 min drive would be possible, but it still is a open header.
Old Nov 20, 2003 | 10:55 AM
Jowee's Avatar
Do you have excessive carbon build-up due to this header? Would it turn my engine bay all black or melt my bumper? Any more pix of the exit of the header on the car?
Old Nov 20, 2003 | 11:32 AM
Trooper's Avatar
My bumper didnt melt, there is about 5-6 inches between the header and the bumper. Although my car did idel for about 7 hours, I only got 5 passes in it, but i saw no sigens of the bumper melting. But that was on a EG, I also didnt see any carbon buildup, but at night I could see some dope *** purple flames !!
I do have more pics they will be up in a few min
Old Nov 20, 2003 | 11:37 AM
Trooper's Avatar
Here is a better one, dam DOS ftp mesed up the images, but here is a Idea on the length.
Old Nov 20, 2003 | 11:53 AM
96AllMotorDC2's Avatar
bump for trooper. great guy! buy his stuff.
Old Nov 20, 2003 | 12:56 PM
Trooper's Avatar
Up
Old Nov 20, 2003 | 01:27 PM
Trooper's Avatar
Here ya go
Old Nov 20, 2003 | 02:04 PM
Trooper's Avatar
Default Re: ¡Âà ƒÂ‚Ã‚Â¡ÃƒÂƒÃ‚Â‚ÃƒÂ‚Ã‚Â¡
bump
Old Nov 20, 2003 | 02:07 PM
k20pinay's Avatar
damn trooper you have some white legs....
naw, just playing, can't be as bad as john's, my little white man
Old Nov 20, 2003 | 02:11 PM
Trooper's Avatar
Default Re: ÂÂà ƒÂ‚Ã‚Â¡ÃƒÂƒÃ‚ÂƒÃƒÂ‚Ã‚Â‚
So what if my legs are white lol.
Old Nov 20, 2003 | 02:22 PM
Bump! For the Troop sauce! Buy his ****!
Old Nov 20, 2003 | 03:11 PM
Jowee's Avatar
Default Re: ÃÂà ƒÂ‚Ã‚Â‚ÃƒÂƒÃ‚ÂƒÃƒÂ‚Ã‚Â‚
**DROOOLSSSS** I need to come up with some cash. Are you willing to negotiate the price for anything in my sig?
Old Nov 20, 2003 | 03:32 PM
Trooper's Avatar
Default Re: ÃÂà ƒÂ‚Ã‚ÂƒÃƒÂƒÃ‚ÂƒÃƒÂ‚Ã‚Â‚
Sorry I need the Cash , Got in a bit of Financial trouble.
Old Nov 20, 2003 | 03:38 PM
WayneGro's Avatar
1)How loud is that header? Is it streetable? Did you street it?
2) Would it be possible to attach a custom exhaust to that header, to quiet things down a bit?
Old Nov 20, 2003 | 03:39 PM
Trooper's Avatar
Well since the header has revision tubes, its not loud but you still know that the car is off of the header. If you look closley after the Primary colector it is detachable and I am sure that Hytech could either make you a muffler or you could have a Muffler shop attach one.
No I didnt street the car it was for my track car, and If you attach a muffler if would definatley be fesiable for the street.
Old Nov 20, 2003 | 10:57 PM
Trooper's Avatar
bump
