Question about turbo mani, Lovefab SST for LS
Old Nov 20, 2003 | 06:06 AM
94lsboost's Avatar
Default Question about turbo mani, Lovefab SST for LS
Does this manifold require the removal of Power Steering as well as A/C? I know you lose a/c but ps too???
Old Nov 20, 2003 | 06:07 AM
94lsboost's Avatar
Default Re: Question about turbo mani, Lovefab SST for LS (94lsboost)
I am told you can grind a little off the PS bracket and it will work
Old Nov 20, 2003 | 08:33 AM
tegmech's Avatar
dude, its just the same in the fi forum. all you need to do is grind a little. If your so worried about it then go with the sidewinder, then you don't lose anything.
Old Nov 20, 2003 | 08:48 AM
94lsboost's Avatar
Default Re: (tegmech)
Yeah I would have went with a cheaper one all together b/c this is a budget build, but it's part of a deal i'm getting...
Old Nov 28, 2003 | 05:04 PM
Cyphear's Avatar
I think you only have to remove AC if you are running 3" downpipe. And i'm not sure about the P.S. question, but i know its either its okay, or only slight modification.
Old Nov 28, 2003 | 10:06 PM
AP-Signworks1's Avatar
Default Re: (Cyphear)
I'm pretty sure you lose the AC too. On other manifolds, a 3" downpipe won't clear the compressor either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyphear &raquo;</TD></TR><TR><TD CLASS="quote">I think you only have to remove AC if you are running 3" downpipe. And i'm not sure about the P.S. question, but i know its either its okay, or only slight modification.</TD></TR></TABLE>
Old Nov 28, 2003 | 10:34 PM
Mase's Avatar
Default Re: (AP-Signworks1)
or you could go full-race and keep ac and powersteering
Old Nov 29, 2003 | 08:29 AM
94lsboost's Avatar
Default Re: (Mase)
I got this manifold in a trade, so that's why i'm running it, i would have probably gotten a less expensive one otherwise. Looks like i dump the A/c which I am ok with, and trim the power steering bracket and it's
thanks for the answers once again!
Old Nov 29, 2003 | 09:16 AM
Ri5e's Avatar
Default Re: (94lsboost)
Better off if you posted this in the Force Induction forum and also message Tinker219, he'll be able to answer all your questions
Speed94
May 10, 2008 04:40 AM
lacking vtec
Apr 19, 2006 05:25 PM
Noch
Mar 25, 2004 07:51 AM
civbeater90
Jul 9, 2002 03:11 AM
