94/95 Accord Info Needed...
I can find interior/exterior dimensions, MPG info, engine info.......basically the info I don't need and already know.
4th Gen Prelude idea failed, so 94/95 Accord Sedan is it now.
Brakes are my question. Which models came with:
1) ABS?
2) Four Wheel Disc Brakes?
From what can figure, the EX is the only model....right? I'd be nice if a DX came that way.
The search came up with one HTer doing a RDC on his Accord, but nothing mentioned what his model was, and the repling post never mentioned what model of Accord he got his parts from. And he was talking about a 90/93 Accord I believe.
I'm somewhat tired of doing conversion (from the Civic family), so I just want a car with it already, set, go. I just want to upgrade the stock four wheel disc.
1) ABS?
you don't want ABS. on the accord, it takes up too much room under the hood. but yes, the EX it came with, an option on the LX, not available on the DX (i don't think). i'm not sure i'm reading right, but if you want 4 wheel discs, you can buy a DX/LX and just upgrade the rear, or buy the EX that has them standard.
burnin up tha track,burnin up this track/
have wankstas pumpin crack,cuz they lack/
wat it takes to clutch tha clutch,Mitsubishi who gives a ****/
cuz im bout tha Honda so u **** out of luck/
10 seconds on tha board,so home wats yo score/
let me see wat u got V6 or V8,ya'll hate/
me thats great,aint none of ya'll hangin u out of shape/
4 cylinders burnin hot,run yo azz ova on tha spot/
stay of mah streets,or nitrious gonna heat it up/
Honda Accord,all tha otha **** ya'll got jus so bored/
bodykit bag it,put yo mitsu on tha street and ima trash it/
12's and amps,wanna drive tha best then talk to me bout camp/
ya'll aint got me so trust,but ya'll got mah dust/
thumpin ere second,homie im hittin 140 and aint wreckin/
Hondas are wat u want,not a mitsu if u ready to get tha streets crunk!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caddy_Turns »</TD></TR><TR><TD CLASS="quote">burnin up tha track,burnin up this track/
Hondas are wat u want,not a mitsu if u ready to get tha streets crunk!</TD></TR></TABLE>
This is pointless. Peeps like you will not be like here on HT. Keep giving uniformational post, to rack up post count, and you'll be outta here. Go post ***** in the GDD Forum, once your out of noob stage.
iakona: Thanks for the response. I don't really care about ABS, but I figured it would be a standard feature on any Accord 94+. I just want to have a four wheel disc, manual, sedan. I don't care for the ABS or any power features.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrreeeBird »</TD></TR><TR><TD CLASS="quote">See sig, very reliable, i get 22-26 mpg city and 32-38mpg highway . . . .</TD></TR></TABLE>
I'm 3000 miles away.
Thanks though.
Thanks though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona »</TD></TR><TR><TD CLASS="quote">yeah, if you don't care for the ABS,then just get a DX or an LX and swap in the rear discs. good luck in your search! </TD></TR></TABLE>
What parts are needed? I only know of SOHfast.com that sells RDC, but they're only for Civics.
if you go the yard, just pick up the rear trailing arms with everything attached and the brake lines and the e-brake cable. i think that should cover everything. but you may want to buy new lines anyways. i have the goodridge ones and they are pretty nice. but the disc has a 6-piece line package while the drum only has a 4-piece line package.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona »</TD></TR><TR><TD CLASS="quote">if you go the yard, just pick up the rear trailing arms with everything attached and the brake lines and the e-brake cable. i think that should cover everything. but you may want to buy new lines anyways. i have the goodridge ones and they are pretty nice. but the disc has a 6-piece line package while the drum only has a 4-piece line package.</TD></TR></TABLE>
Thanks. I've got 2 Honda/Acura junkyards close by, so I'll give them a call.
