bunch of Honda and turbo stuff for sale....
damn...there are a shitload of items going to have to do links (counted 36 pics):
<FONT SIZE="4">MAKE A REASONALBE OFFER</FONT>
DOHC ZC timing cover, ok shape
throttle body from DOHC ZC dashpot thing was broken off by the importer, should work fine NO TPS
88-91 Civic/CRX coolant overflow tank
set of *brand new* spark plug wires for 88-91 Civic/CRX 1.5/1.6L SOHC motors
Honda OBD0 resistor box (i have two)
wastegate acutator/downpipe/O2 housing/whatever from a SAAB/Garrett T3 turbo yes it has an adj. WG arm (will sell seperate, looks like there is a broken bolt in it)
throttle body from a 88-89 Prelude Si (2.0) NO TPS
WG acuator off a 60/63 T3 turbo (Turbocoupe/SVO)
Honda 240cc injectors a shitload of them
OBD1 PR4 ECU
WG acuator off a MK2/2.5L turbo Chrylser
IACV for Honda motors (not sure what cars but they fit D16A6's, A1's, and my LS motor) i have 3+
86-87 PG7 ECU
D-series starter probly only fit 88-91 (i have two, TESTED and GOOD)
CRX/Civic Si hubs/calipers/rotors (you need these for your HF/Std engine swaps. good bearings, Hawk HSP pads [used 6 months, no racing], bought rotors at the same time as pads)
another SAAB WG housing thing
a couple Honda oil pressure senders
D16A6 engine block *BARE*
Chrysler exhaust turbo housing .42ar
88-89 Integra throttle body *WITH GOOD TPS*
Ford turbo O2 housing
D16A6 crank
D16A6 head
88-89 Integra/ZC distributor *MISSING IGNITOR*
Ford turbo O2 housing w/3wire sensor
SAAB .42 compressor housing *NOTE* it should be noted that this turbo broke the turbine shaft so the housing is a little scapped up on the inside
CRX HF rear hatch
88-91 Civic/CRX washer tank
88-89 passenger side bumper light *AMBER* (you can probly get it to work on the other side)
Bosch/SAAB blow off valve
throttle body gasket *BRAND NEW* (part number is in pic, was bought for Z6)
88-89 bumper light drivers side i think
88-89 Accord LX-i throttle body *WITH GOOD TPS* (same TPS used on all MPFI Civic's)
fuel rail off a HF motor
stock EF/CRX radiator fan (i have two, one with a plug one without)
Integra EGR valve think its the same for all Honda's 88-up
btw if it doesnt say what car its for its probly for a CRX...
holy **** that was a lot of stuff...
if you didnt notice there are a bunch of items, SO PLEASE LABEL YOUR PM'S SO I KNOW WHAT YOUR TALKING ABOUT. i dont mind questions i just need to know what your talking about. btw i prefer PM's or posting, dont email me cuz i dont check it often (you can IM me too). thank you...
my ZIP is 98037, i live in Lynnwood, WA. local pickup is always perferd. cash for pickups, PayPal for shipped items...
OBD1 PR4 ECU
86-87 PG7 ECU
D16A6 crank
D16A6 head
CRX HF rear hatch
Jap_Spec_Imports
Aug 12, 2006 12:55 PM
