JDM 95B16a SiR2 for sale....modded awell.....
Ok,,i am selling my 95 JDM B16a. It has around 13k on the motor and it's coming with an Si tranny which has 19k on it as of now. I have receipts and paper work for this motor if you want. I am running mid to low 13's with this motor going ALL MOTOR in my hatch.
Motor has new head gasket, new timing belt, new nuts and bolts where replaced.
Also new GSR motor mounts all the way around
mugen thermostat
new radiator hoses
thinner head gasket compression is at 10.7
new alternator
new distributor
Stage 1 clutchnet clutch (10k on it)
7lb fidanza flywheel (3k on it)
The Motor has a Port and Polished Head, intake manifold
shiftlinkage
GSr axles
GSR harness, already wired so all you have to do is drop it in and plug everything up (like 4hours of work)
P28 ecu with skunk2 program on it (vtec@5700/revlimiter@8500)
new SiR plug wires
NGK platinum plugs
compression tested one month ago had 225 across all four
Mobil Synthetic 1 5w30 always every 2k
All these mods would cost like 5k to put together, you are getting a complete swap, and when you pick it up you can see that my car is running, and running fast. My car runs Mid 13's on motor,,that's a 1.6 all motor b16 rocket, very fast for what it is.
I am starting the price at 3700, remember all the work and how new the motor is and al the new parts that have been replaced. Well worth the money.
so, $3700 maybe a little less but dont' low ball me, make some offers. I am located in South florida and i will not deal with shipping,,WILL NOT, come pick it up,,your more than welcome. thanks
Milan
mugen thermostat
new radiator hoses
new alternator
new distributor
shiftlinkage
GSr axles
new SiR plug wires
NGK platinum plugs
Milan
