Oil Pressure Gauge Fitting adapter?
Old Nov 19, 2003 | 07:35 PM
GBRacing's Avatar
Default Oil Pressure Gauge Fitting adapter?
Just curious as to see if anyone has used this adapter from http://www.nissport.com. It runs for $49 but I don't know if the simple "plug and play" is worth the cost. Thoughts?
Old Nov 19, 2003 | 10:14 PM
mmuller's Avatar
Mad Scientist
Default Re: Oil Pressure Gauge Fitting adapter? (ITACRX)
i dunno... it says for turbo lines, oil press. and stock dummy light, i would not use that to run any other lines besides oil pressure, and if the stock pressure switch is in there too, i would fear the whole thing to vibrate itself out...
Old Nov 20, 2003 | 04:09 AM
EX-T's Avatar
Default Re: Oil Pressure Gauge Fitting adapter? (mmuller)
I got a brass T fitting from Napa auto parts for a few bucks and it worked fine. The only problem that I had was the plastic tubing broke one day when I was taking my oil filter off.
Old Nov 20, 2003 | 05:35 AM
PupaScoopa's Avatar
Default Re: Oil Pressure Gauge Fitting adapter? (DSeriesBKilla)
I found a few manifold-type products mentione don clubsi.com (it's in a sticky) which may work out for you. I'm thinking of going with a brass-T myself.
Old Nov 20, 2003 | 06:15 AM
RCautoworks's Avatar
Default Re: Oil Pressure Gauge Fitting adapter? (PupaScoopa)
Here is my setup, mounted it on the firewall.
I do not recommend mounting anything besides the stock dummy light on the engine. I have seen people that mounted there oil sender on there block and have it fly off on the high way. Not something you want.
Old Nov 20, 2003 | 09:20 AM
GBRacing's Avatar
90blackcrx,
I like what I see. What kind of line is that?
Old Nov 20, 2003 | 12:06 PM
Default Re: (ITACRX)
Its actually copper tubing, autometer sells it.
hotshot100
Apr 14, 2010 05:10 PM
importdude2000
Jul 6, 2006 04:09 PM
B18badboy
Apr 12, 2006 07:17 PM
88crxhfb16
Jul 23, 2005 11:02 AM
accordfreak
Jan 27, 2004 12:52 PM
