Anyone ever run without there front swaybar?
Old Nov 19, 2003 | 06:46 PM
precord96's Avatar
Default Anyone ever run without there front swaybar?
Im thinking of doing this, just wondering if anyone had tried.
I have full suspension, teins, strutbars, tiebar, rear s/t swaybar, rollcage.
Old Nov 19, 2003 | 08:26 PM
Pauldo's Avatar
I don't have mine on. I don't like it much. The inside front wheels lifts to early when cornering, it sucks. I have to find some poly bushings and slap that sumbitch back in.
I'm using front and rear STB's, rear ST sway bar, H&R OE sports, and KYB AGX (3/6)
Old Nov 20, 2003 | 07:00 PM
blackaccord96's Avatar
Default Re: (CB7 Driver)
i perfer not haveing one but i do like them just because they allow you to take turns at higher speeds
Old Nov 21, 2003 | 03:06 AM
urbanlegend21's Avatar
New User
Default Re: (blackaccord96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackaccord96 &raquo;</TD></TR><TR><TD CLASS="quote">i perfer not haveing one but i do like them just because they allow you to take turns at higher speeds </TD></TR></TABLE>
this is the dumbest logic I have ever heard
I do not run one on my race car. It helps rotation but tends to lighten the inside wheel. I am also running 800 lbs springs up front. Try loosening the bar first. See if that gives you the results you want. Or look into getting a custom bar made for the rear, you know, something like 27-28mm in size.
Old Nov 21, 2003 | 07:28 AM
olboy81's Avatar
Default Re: Anyone ever run without there front swaybar? (precord96)
I've ran without it before and the car does sway alittle bit in turns.
Old Nov 21, 2003 | 08:44 AM
97F22B2's Avatar
i love mine, but i have mad understeer my i have gotten used to it. I wouldnt drive anywere without mine
Old Nov 21, 2003 | 11:25 AM
Default Re: (urbanlegend21)
thanks urbanlegend21
Old Nov 21, 2003 | 03:12 PM
precord96's Avatar
I guess, ill just keep mine in then. Thanks
Old Nov 21, 2003 | 03:34 PM
WuWarrior's Avatar
It would be far better to get a larger rear sway bar instead.
Old Nov 21, 2003 | 03:42 PM
NathanMorris's Avatar
Default Re: Anyone ever run without there front swaybar? (WuWarrior)
you don't want a front sway bar on a FWD car, you want a rear one, and a thick rear one at that. And if you have a front sway bar, you want a small one if a tall.
- Nathan
D16SohcVtec
Suspension & Brakes
Mar 18, 2007 01:23 PM
Charbon Sty
May 7, 2005 09:34 PM
socalep3
Jan 5, 2004 08:19 PM
J-g-D-s-M-r
Aug 6, 2003 11:16 PM
ken-shin
Jun 16, 2003 01:52 AM
