i got some ecu codes yada yada
Old Sep 12, 2001 | 05:36 PM
JunkeeCrx's Avatar
New User
Default i got some ecu codes yada yada
ok, i know what they are, just not totally sure how to fix them. i little help would be awesome. well any help for that matter too.
code 8 - TDC(top dead center) sensor
this one has me puzzled. isnt this in the disributor? I have a brand new distributor, and if its located in here, im gunna be pissed! could it also, be working, and i just have a problem with my timing?
code 12- EGR system
I know about this one. but any suggestions would be cool
code 16 - Fuel Injector
a little puzzled on this one too. does it mean it needs to be full on replaced, or can i just replace certain parts of it to fix it?
by the way im in a 91 crx dx. woo!
so yeah if any of you tech heads got some advice, i'd appreciate it!! thanks!
Old Sep 12, 2001 | 05:52 PM
dustin's Avatar
Default Re: i got some ecu codes yada yada (JunkeeCrx)
TDC sensor is in the distributor
Old Sep 13, 2001 | 09:13 AM
kahren's Avatar
Default Re: i got some ecu codes yada yada (dustin)
your fuel injectors might just ahve a loose connection so unplug them and check the connector
Old Sep 13, 2001 | 09:36 AM
JunkeeCrx's Avatar
New User
Default Re: i got some ecu codes yada yada (kahren)
will do, thanks!
Old Sep 13, 2001 | 02:34 PM
fixhondas's Avatar
code 16 will be fixed with a main relay
code 8 maybe an old code if it was not cleared when you replaced the distributor- is your distributor an aftermarket reman piece of ****? If this code is new you will most likeley need a distributor.
You got a code 12 on a DX??? must be a CALI model. Could be valve itself or solenoid or cvc valve or a plugged air chamber.
Old Sep 13, 2001 | 03:42 PM
JunkeeCrx's Avatar
New User
Default Re: i got some ecu codes yada yada (fixhondas)
actually it is an after market distrib. should got the oem one i guess. and it is a cali model. I found that out when i got the car, some dude had a ticket stuffed in the little pocket behind the drivers seat. issued in cali. weird. thanks for the info though!
romierome
Feb 24, 2010 12:01 AM
Crackback
Mar 12, 2008 06:22 PM
kwizical
Jan 11, 2008 09:55 AM
h22Sicoupe
Mar 31, 2007 08:08 PM
Airbag Club
11
Mar 10, 2005 03:05 PM
