What do you guys think about HCP mounts and adjustable shift linkage?
Old Sep 12, 2001 | 05:13 PM
MysteryWagon's Avatar
Default What do you guys think about HCP mounts and adjustable shift linkage?
I am getting a B18c of course, but I want to know about the HCP's before I go digging in my pocket for more doe.
DO you think they could hold turbo on the engine you know with the Fourth mount? WHat do you guys think?
Thanks guys
Old Sep 12, 2001 | 07:57 PM
rioninja's Avatar
Default Re: What do you guys think about HCP mounts and adjustable shift linkage? (ShaggenWaggon)
I have em, and love em. Made from steel, with a lifetime warranty on the polyurethane. I have used the same kit with 2 different motors, and both times it went in without a hitch.
Old Sep 12, 2001 | 08:00 PM
Blown90hatcH's Avatar
Default Re: What do you guys think about HCP mounts and adjustable shift linkage? (RioNinja)
HCP is what I exclusively use!! I have used them in all my swaps that I have done and in my car. 90 civic hb B18C turbo upping the boost to 28psi later this year.....this is all I run. HCP has the 4th mount....this is what I needed. The shift linkage gives people grief.....but once you have it figured out...it works great.
Let me know if you need a kit...I get them for like 415 +shipping with adj linkage
Jason
Old Sep 12, 2001 | 10:07 PM
Default Re: What do you guys think about HCP mounts and adjustable shift linkage? (Blown90hatcH)
cool, thanks alot dude
hey are any of you going to NOPI rice world, I am just going to see the big daddys that yopu know wioll be there, and to get some races.
thanks
Old Sep 13, 2001 | 04:46 AM
TypeR0207's Avatar
I asked the same question a few weeks ago, run a search in my name, some others had some answers.
I got the HCP ones, and they came in last week. Now I just need the motor and axles!
Old Sep 13, 2001 | 05:34 AM
Doodoo's Avatar
Got them, have turbo now. Love 'em and turbo sits nicely.
Old Sep 13, 2001 | 11:21 AM
crux131's Avatar
Default Re: What do you guys think about HCP mounts and adjustable shift linkage? (Doodoo)
Can I run AC with these mounts, and no extra aftermarket brackets??? I have the AC compressor from the integra the motor came out of, I also have my factory AC system....from the 1.5 liter. If so which AC system do I need to use?
This is the first swap I have had experience with, and I want AC....it's damn hot in Alabama sometimes,yo
[Modified by crux131, 4:19 PM 9/13/2001]
Old Sep 13, 2001 | 12:46 PM
bigD's Avatar
Does anyone know if the hasport shift linkage will work with the hcp mounts?
Old Sep 13, 2001 | 01:35 PM
EVOCELICA's Avatar
New User
Default Re: What do you guys think about HCP mounts and adjustable shift linkage? (2000-B18C1)
I doubt it will because the motor is poistioned differently
Old Sep 13, 2001 | 02:38 PM
Chris_'s Avatar
HCP Rules
better price and solid as hell...
the motor went in straight the first time and the shift linkage has given me no problems at all..super solid urethane puts power to the ground like a champ!!
I highly recommend HCP products.............
Old Sep 13, 2001 | 08:37 PM
Default Re: What do you guys think about HCP mounts and adjustable shift linkage? (crxconnection)
The shift linkage will fit in most model EF's with little to no modification.
Old Sep 14, 2001 | 03:55 AM
crux131's Avatar
What about the AC????
Thanks!
Old Sep 14, 2001 | 09:20 AM
Doodoo's Avatar
Default Re: What do you guys think about HCP mounts and adjustable shift linkage? (crux131)
You can do A/C, if you got the patience. You need to get the Hasport bracket or make your own. Just go with out it, its not hot all year long, and its a PITA. If you go turbo, have fun, it will be very cluttered. There is a write up of the HAS bracket on the crx hybrid board too.
Old Sep 14, 2001 | 10:55 AM
One8Hatch's Avatar
New User
hows the vibration with the hcp mounts? im using hasport mounts in my ef and at idle the cabin shakes a little..
Old Sep 14, 2001 | 08:14 PM
Default Re: What do you guys think about HCP mounts and adjustable shift linkage? (One8Hatch)
You can run the PWO ac bracket that will work. You can make the ac work fine....The vibration is not bad at all. I dont notice it.
Freezen
Feb 13, 2010 11:08 PM
EF9-CIVIC
Jan 12, 2007 11:53 AM
Fred n J_v2.0
Aug 27, 2003 05:10 PM
dingusjt
Jan 8, 2003 08:56 AM
Rob!
Sep 20, 2002 03:55 PM
