TRADE: my eg for your eg!
here's the specs on mine:
-92 Si hatch
-jdm b16a2 motor
-2000 Si tranny w/ Quaife LSD
-ACT clutch
-ngk wires
-**added JDM 4-1 header w/heatshield**
-dual core radiator
-ngk wires
-crower cam gears
-jdm sirII airbox w/ Spoon filter
-skunk2 ecu
-apex'i vafc
-gunmetal valve cover
-**added a custom made 2.5" BENEN exhaust w/ ES oval muffler (no cat)**
-tokiko blue shocks
-ground control coils
-camber kit
-**added 15" flat black rota slips**
-NEW dunlop FM901's 195/50/15
-**black Volk lugnuts**
-extended wheel studs in front
-jdm sirII sidemarkers
-jdm sirII corner lights
-VIS carbon fiber lip
-VIS carbon fiber hood
-real Spoon carbon fiber duckbill
-entire car stripped down and painted Saphron Metallic from a volvo s80 (entire car including engine bay, door jambs, interior, etc.) *$3000 paint job
-jdm sirII gauge cluster
-jdm honda access single DIN block off tray
-jdm sirII optional center consel
-spoon shiftknob
-jdm C's short shifter
-**added a MOMO steering wheel**
-replica spoon mirrors
-interior is stripped behind the front seats, but i will include the entire rear interior with the car
-dyno'd at 168 whp.
here are pics: https://honda-tech.com/zerothread?id=652229
car is in excellent condition. just changed the timing belt and water pump. just had an oil change, and valves tightned. replaced entire left window assembly (regulator, seals, etc.), replaced entire seal under windshield (cowl and seal). sunroof works fine. no power steering. also included is the stock hood, wing, mirrors, entire rear interior (including the cargo cover), an alpine CD player, stock front lip, A/C (which is out of the car right now) and all the other misellaneous parts i have for the car. the front bumper has a couple chips in it, but other than that, the rest of the car is perfect. the body has 0 dings in it, and is the best looking body for a 92 that i've ever seen.
I'm looking to trade for a 92-95 BLACK civic hatch that already has a swap, and is in good condition. email me, or post here if you are interested. thanks. email me at: aharvey56@hotmail.com. thanks.
-92 Si hatch
-jdm b16a2 motor
-ACT clutch
-ngk wires
-dual core radiator
-ngk wires
-crower cam gears
-skunk2 ecu
-apex'i vafc
-tokiko blue shocks
-camber kit
-spoon shiftknob
-dyno'd at 168 whp.
