Bad throttle response
Old Nov 19, 2003 | 02:33 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default She's angry at me again :( - bad throttle response
Well, the tanker is mad at me again for some reason. At full throttle, car bogs severely at 4500 rpm, then acts as if it's catching up to itself through vtec. It's probably some sort of ignitor problem.... plugs? distributor? timing off? too little or too much fuel? coils in the distributor? fuel filter? poo on the rotor?
Fuel set up is Vortech Fuel Rail, Vortech FPR, Walbro 255, VAFC
any suggestions where to start? Same symptons coming back from expo before the R hit the tow truck
Old Nov 19, 2003 | 02:35 PM
Jason's Avatar
Default Re: She's angry at me again :( - bad throttle response (RealTypeR)
I think you're the only person that his this many problems w/ a Honda product...what do you do to her
Old Nov 19, 2003 | 02:40 PM
ZygSpeed's Avatar
Default Re: She's angry at me again :( - bad throttle response (Jason)
Timing belt tension, cam gears slipped?
What was the problem last time?
Old Nov 19, 2003 | 02:41 PM
ILUVTEC's Avatar
I cant believe that we(or I) have to fix your damn tanker again
Buy me and I'll fix
Old Nov 19, 2003 | 02:57 PM
98ITR#0020's Avatar
Sounds like my car before I replaced the distributor..could be the ignitor as well. My buddy has luck like you; none
Old Nov 19, 2003 | 03:14 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: She's angry at me again :( - bad throttle response (98ITR#0020)
Damn, Marc. I've never seen a person more hated by a car than you
Sorry to hear about the latest problems tho
Old Nov 19, 2003 | 03:45 PM
ITR764's Avatar
Default Re: She's angry at me again :( - bad throttle response (Splat)
what plugs you got in it? ngk?
Old Nov 19, 2003 | 03:47 PM
Smitdog's Avatar
Default Re: She's angry at me again :( - bad throttle response (ITR764)
To Much attention paid to the opposite sex then your tank, it is jealous...
Old Nov 19, 2003 | 04:36 PM
D's Avatar
D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason &raquo;</TD></TR><TR><TD CLASS="quote">I think you're the only person that his this many problems w/ a Honda product...what do you do to her </TD></TR></TABLE>
nah, he's just one of the many out there with two left hands.
D
Old Nov 19, 2003 | 05:06 PM
Default Re: She's angry at me again :( - bad throttle response (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">
D</TD></TR></TABLE>
easier to beat your *** with dick
Old Nov 19, 2003 | 05:07 PM
Opie's Avatar
Default Re: She's angry at me again :( - bad throttle response (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Timing belt tension, cam gears slipped?</TD></TR></TABLE>
Don't integra's have a fail safe that turns the car off though if your timing belt should miss a tooth on a cam gear?
Did this happen to you Marc?
Old Nov 19, 2003 | 05:19 PM
chad's Avatar
Moderator
Default Re: She's angry at me again :( - bad throttle response (opie112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie112 &raquo;</TD></TR><TR><TD CLASS="quote">
Did this happen to you Marc?</TD></TR></TABLE>
HAHAHAHAHAHAHAHA......more BS from INTERNET!!!!!!!!
Old Nov 19, 2003 | 05:28 PM
Opie's Avatar
Default Re: She's angry at me again :( - bad throttle response (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
HAHAHAHAHAHAHAHA......more BS from INTERNET!!!!!!!!</TD></TR></TABLE>
Not BS, reality!
This past summer a friend and I were driving from work in his 98' GSR. There was a bang bang (flame suit ready) and then nothing, the motor just turned off and wouldn't kick over again.
When we opened it up the next day we saw that the timing belt had skipped a tooth some how( guessing that much, because of the amount of slack in the belt) and grinded into the shield.
Figured the reason for the motor shutting off would be to prevent valves from bending and other catostrophic **** happening to your motor.
Old Nov 19, 2003 | 05:32 PM
.RJ's Avatar
.RJ
hahahaha!!!!
It wouldnt re-fire because the cams were so far out of time with everything else....
Old Nov 19, 2003 | 06:02 PM
Default Re: She's angry at me again :( - bad throttle response (.RJ)
cap, rotor are aligned fine, plugs are fine. I'm convinced she just hates me
Old Nov 19, 2003 | 06:33 PM
ATL-R's Avatar
I had the same problem with my 2000 R a couple weeks ago. I took it to Acura and they changed the whole distrubitor, the spark plugs, and the wires. This still didn't fix the problem. It ended up being the throttle body and the sensor that lies on it. It is a hard problem to diagnose, it could be a number of things. good luck
Old Nov 19, 2003 | 06:58 PM
Haunt's Avatar
Marc...
Sounds like mine when my distributor died too, except mine was doing other weird things as well. Change that out if you or some of your Florida buddies have an extra laying around.
Its an easy test...
BTW...how many times has that thing died on you now? You need to rebuild again...
Tom
Old Nov 19, 2003 | 07:19 PM
BlueR's Avatar
uhm ok...maybe his flux capacitor is broken
realtor: that happened to me 2 months ago...i soaked my distributor by accident, dried up next day and car ran fine
Old Nov 20, 2003 | 04:31 AM
cw98typer's Avatar
[QUOTE=opie112]
hhhaaahahahahahaha
Old Nov 20, 2003 | 04:42 AM
Default Re: She's angry at me again :( - bad throttle response (cw98typer)
Coils in the distributor were replaced on the way back from Expo in April. I don't think it's that, or at least I hope not...
Old Nov 20, 2003 | 04:51 AM
Johnny Tran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Coils...</TD></TR></TABLE>
w0w!
theres your problem....take all but one out
Old Nov 20, 2003 | 09:36 AM
Default Re: She's angry at me again :( - bad throttle response (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
realtor: that happened to me 2 months ago...i soaked my distributor by accident, dried up next day and car ran fine</TD></TR></TABLE>
although we've had a lot of rain lately, it's beautiful today and she limped in to work.
Old Nov 20, 2003 | 10:51 AM
RockstarJR's Avatar
Marc has just had too many 200+ pounders riding shotgun.
Old Nov 20, 2003 | 12:20 PM
Dave-ROR's Avatar
Default Re: She's angry at me again :( - bad throttle response (ILUVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILUVTEC &raquo;</TD></TR><TR><TD CLASS="quote">I cant believe that we(or I) have to fix your damn tanker again
Buy me and I'll fix </TD></TR></TABLE>
You fixed it before? I thought the only thing you did was get the car kicked out of all future CFR SCCA autocrosses by driving like an idiot at the fairgrounds? (or have they forgotten and let marc back in?)
Old Nov 20, 2003 | 12:21 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">hahahaha!!!!
It wouldnt re-fire because the cams were so far out of time with everything else.... </TD></TR></TABLE>
correct.
