mugen bushings same as oem itr?
Old Nov 19, 2003 | 01:41 PM
euclid's Avatar
Default mugen bushings same as oem itr?
it was rumored that the mugen trailing arm bushings are just oem itr bushings. i want to be sure before i order them from king.
also, i am thinking of replacing my hasport/jimfab motor mounts with something alittle softer. if the mugen mounts are just relabled oem i will save myself some $.
anyone know for sure? i read the mugen mounts actually have honda part#'s on them.
finally, does anyone know the proper sequence to torque the 5 motor mounts down? thanks
Old Nov 19, 2003 | 02:10 PM
jdm civic 2000's Avatar
Default Re: mugen bushings same as oem itr? (euclid)
y dont you just replace with energy suspensions bushings??,
Old Nov 19, 2003 | 02:15 PM
euclid's Avatar
Default Re: mugen bushings same as oem itr? (jdm civic 2000)
i have prothane rear trailing arm bushing in now, i want the free movement of an oem type.
Old Nov 20, 2003 | 12:43 AM
euclid's Avatar
i emailed king motorsports about it, they replied and said the mugen bushings are much stiffer than oem itr.
bump for the other question about the mounts torque order.
Modified by euclid at 6:42 AM 11/20/2003
Old Nov 20, 2003 | 05:37 AM
PupaScoopa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm civic 2000 &raquo;</TD></TR><TR><TD CLASS="quote">y dont you just replace with energy suspensions bushings??,</TD></TR></TABLE>
Because there was a huge controversy about using non-OEM style rear trailing arm busings. They cause problems with the suspension geometry and binding.
Old Nov 20, 2003 | 01:46 PM
Default Re: mugen bushings same as oem itr? (PupaScoopa)
i use them i dont have geometry problems and or binding for that reason,i drive hard and i did an alignment few weeks ago and i was all set on the rear,nothing had to be touched,so to each is own i guess on this argument
Old Nov 21, 2003 | 08:15 AM
euclid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm civic 2000 &raquo;</TD></TR><TR><TD CLASS="quote">i use them i dont have geometry problems and or binding for that reason,i drive hard and i did an alignment few weeks ago and i was all set on the rear,nothing had to be touched,so to each is own i guess on this argument</TD></TR></TABLE>
when the car is at rest it will not be binding, an alignment wont tell you anything. its when the suspension goes into its range of motion that a solid bushing will bind it.
Old Nov 21, 2003 | 12:30 PM
reguardless,i have had energy suspension bushing for 2 rs now,no problems.....the pupose is to make the rear feel and travel less freely then oem bushings,it helps out on the bouncy ness of factory bushings,and also helps alot on sway as well when cornering......
you also gotta rember that trail arm bushing is takin all the abuse on the rear end,at rest a cheap rubber compound will rest alot more then a urethane compound,this will effect alignment, because the cheap rubber tends to feel what the weight of the car wants to do and may throw off the alignment,and will affect the toe and camber off slightly,th eurethane compound is much stronger and will keep its shape better at rest and in active use.....but i could be wrong
Old Nov 21, 2003 | 03:09 PM
b18crx's Avatar
ive heard never to use energy or prothane---or any poly trailing arm bushing. i use the mugen ones....
Modified by b18crx at 10:56 PM 11/21/2003
Old Nov 21, 2003 | 07:53 PM
magnum's Avatar
Default Re: mugen bushings same as oem itr? (b18crx)
And I guess you are paying that extra Mugen price tag!!!
My ES Bushings are great, really tightens up car!!!
Old Nov 21, 2003 | 10:36 PM
PHiZ's Avatar
Default Re: mugen bushings same as oem itr? (magnum)
The mugen bushings cost about what the prothane ones do, you can't compare the ES ones on price, because they dont' come with any of the metal parts.
Reusing the metal bushing cups and post , after torching and hacksawing it out is
-PHiZ
Old Nov 22, 2003 | 01:58 AM
euclid's Avatar
Default Re: mugen bushings same as oem itr? (PHiZ)
i paid $125 for my prothane bushings, im about to pay $104 for the mugen.
Tom B
Jun 24, 2016 07:15 AM
Draco
14
May 30, 2011 08:22 PM
Jeff_B
40
Dec 20, 2005 08:29 AM
ninor
Apr 18, 2005 04:35 PM
p1driftfiend
24
Jul 10, 2004 12:25 AM
