Spoon ITR Damper/Spring(progressive) combo
Old Nov 19, 2003 | 01:07 PM
lastlude2k1se's Avatar
Default Spoon ITR Damper/Spring(progressive) combo
My ITR is used for daily driving, auto-x and 1-2 lapping day events/yr. Is this setup good enough? Anyone have experience with these? I've also considered the TEIN FLEX system, but I really don't think I'm going to be making alot of adjustments on my suspension anyways. Does the spoon fixed setup compare to full coilover systems?
Old Nov 20, 2003 | 06:54 AM
Default Re: Spoon ITR Damper/Spring(progressive) combo (lastlude2k1se)
Anyone?
Old Nov 20, 2003 | 06:57 AM
mstewar's Avatar
you should really search.. or PM George Knighton.. there was extensive discussion of these progressives awhile back..
Old Nov 20, 2003 | 07:52 AM
Ok from all the info I have gathered from here, my question is more about the Spoon Yellow non-adjustable shocks. Most people are recommending Bilstein shocks to match up with these springs. Since the Spoon non-adj were made to pair up with the Spoon progressives, would it be better to go with the spoon shocks instead of the Bilsteins? Not to mention the spoon shocks are made by showa.
Old Nov 20, 2003 | 07:59 AM
thk's Avatar
thk
Members Only
Default Re: (lastlude2k1se)
The Spoon non-adjustables? Hell, I'd save my money and just use the stock ITR dampers and Spoon springs (but I wouldn't and didn't).
Old Nov 20, 2003 | 09:57 AM
typer_801's Avatar
Default Re: (thk)
The are a couple problems with using the stock dampers. 1) the car is too low in the rear and 2) the ride is a little choppy. The spring rates are up but the dampening and rebound is still the same. That perfect balance the ITR had isn't there anymore. Still very good, but not great. Handling however is definitely better.
Year One Racing
Nov 26, 2002 02:08 PM
B2FiNiTY
Jan 7, 2002 11:41 AM
