question 1.8 integra ls ECU??
can i use the integra 1.8 ls ecu into the crx 91 si with the dohc zc? and also
which ecu is better to use in dohc zc the crx si 91 ecu chiped or the pg7 88-89 1.6 integra or the ls 1.8 integra? because later on i might go turbo. i will apperciate some help on that thanks.........
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mateencrx91 »</TD></TR><TR><TD CLASS="quote">can i use the integra 1.8 ls ecu into the crx 91 si with the dohc zc? and also
which ecu is better to use in dohc zc the crx si 91 ecu chiped or the pg7 88-89 1.6 integra or the ls 1.8 integra? because later on i might go turbo. i will apperciate some help on that thanks.........</TD></TR></TABLE>
any will work for the zc. i believe the pg7 is supposed to be the best from your list. jdm pm7 is naturally better since the maps were made from the dohc zc. from what i can remember the 90-91 pr4 only revs to 6800, supposedly runs richer than the pg7, and doesnt have a control for the radiator fan. pm6 should also work fine.
if your pm6 is a 90-91 may i suggest ghettodyne or turboedit. you can chip it yourself and download/burn any bin file you want...ie pg7, pr7, and also customise how you want...ie no speed govenor, custom rev limits. also if your gonna turbo you can get custom programs for that also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mateencrx91 »</TD></TR><TR><TD CLASS="quote">i also have chiped the 90-91 si pm6 ecu, and i have no gov and 9000 rev.
can i get the chip for the pg7? </TD></TR></TABLE>
pm6 has no speed govenor...well it does but its set so high youd never hit it without rocket propulsion.
if you put your chip in the 90-91 pm6 with a ZIF socket then you can burn/have burned the pg7 program or any other program for that matter and just pop it in.
beatthisspeed69
May 16, 2006 09:54 AM
4door93civic
Jun 4, 2004 09:42 PM
