Hey guys 88 hf what engine harness can i use????
does it have to be 88 or 89 or 90-91 and only si or have to be HF?????? i have heard that the year matters for if the harness fits in. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legutki »</TD></TR><TR><TD CLASS="quote">Im pretty sure any 88-91 hf or si harness will work. Just make sure its not a dx.</TD></TR></TABLE>
you need to use the harness that matches the model of your car - the HF and Si harnesses are not the same - the wires in the connector to the chassis harness are in different locations in the connector
no... get the exact year... I think the si and the hf are the same.. but 88 is exclusive
89 is different
90-91 is same
I had an 88 hf my buddy had an 89.. they were different plugs.... and wire wires where in different locations.. we learned the hard way
89 is different
90-91 is same
ya tahst what i thought...i think i'm just gonna swap teh underdash out for something else. cause finding an 88 hf will be liek needle in hye (sp) stack....maybe i'll just convert i to eg underdash with clsuter an all
HF and SI engine harnesses are different. Theres 2 pins where it connects to the cabin harness that are different. If you try to use teh si harness on a hf, you will get a code 15, i know this from experience
88 harness is different than the rest, same with the clutch, ecu, etc...
i used the stock 88 harness on many dual cam vtec changeovers, youre asking for a headache if u use any other harness.
fullraceacura
May 24, 2005 09:49 AM
89 pos
21
Mar 9, 2005 09:47 PM
CimorelliCRX
Apr 18, 2002 02:14 AM
