Brake pad question
Old Nov 19, 2003 | 05:31 AM
vabchaccord's Avatar
Default Brake pad question
I've been told that the OEM pads for the front brakes on my 97 EX sedan 4 cyl are ceramic(?). When the previous owner last changed the brakes, I believe she bought cheaper pads from wherever. My question is, if i go to my Honda dealer, will they sell me the actual OEM ceramic (?) pads and do they produce less or lighter dust than the cheapies she had on there? Or, are there others that are ceramic (if that's what the OEM ones were) or whatever that are good and low dust producers? I would prefer to keep the car as stock as possible.
Old Nov 19, 2003 | 05:44 AM
Default Re: Brake pad question (vabchaccord)
P.S. I've heard a few good testimonials on Autozone Carbon-fiber pads with a LLW. Comments on those, and others, also?
Old Nov 19, 2003 | 12:28 PM
Perfectionist's Avatar
I don't remember what they're made of, but I believe the OEM pads are a composite of some sort. Not too hard or soft.
I've always had the best performance from OEM pads. They come with the proper shims and grease. There are better performing aftermarket pads out there, but the ones I tried sucked. Get the OEM pads unless you know someone who positively had verifiable better performance from another brand at the same or less cost. BTW, I bought my parts on line from places like hparts.com, etc.
Old Nov 19, 2003 | 01:25 PM
Qfactor's Avatar
oem pads are semi-metallic.they produce the same amount of brake dust but they are not as hard on your rotors....
Old Nov 19, 2003 | 02:27 PM
Pauldo's Avatar
Why would the dealer sell you anything other than OEM?
Ceramics will produce the least amount of dust as well. IIRC OEM pads are ceramic.
Old Nov 19, 2003 | 08:00 PM
SIMATIC's Avatar
Default Re: (CB7 Driver)
i changed my break pads in the summer using raybestos pads...i noticed a decrease in my stopping power. should i get a set of oem pads?
Old Nov 19, 2003 | 08:06 PM
iam7head's Avatar
Default Re: (SIMATIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIMATIC &raquo;</TD></TR><TR><TD CLASS="quote">i changed my break pads in the summer using raybestos pads...i noticed a decrease in my stopping power. should i get a set of oem pads?</TD></TR></TABLE>
do you bleed the system? turn the rotor/drum?
$$broke_db8
Jun 24, 2006 03:26 PM
hondaracin24
Nov 19, 2004 02:48 PM
TrueUntilDeath.com
Jul 13, 2004 11:35 AM
00TEG
Jul 24, 2003 09:10 AM
Propulsion
Apr 3, 2002 10:53 AM
