B16 CRX radiator?????
Old Nov 19, 2003 | 02:22 AM
goodwinesi's Avatar
Default B16 CRX radiator?????
Will my old HF radiator be sufficient? If not what do you recommend?
Old Nov 19, 2003 | 03:23 AM
Home Skillet's Avatar
Default Re: B16 CRX radiator????? (goodwinesi)
I have a STD radiator and it's been working great with my B16 swap for 4yrs.
Old Nov 20, 2003 | 06:53 AM
goodwinesi's Avatar
How much are the STD radiators. Are they as much as the fluidyne radiators? If not, who carrys them?
Old Nov 20, 2003 | 06:57 AM
quarterkorean's Avatar
STD stands for standard, like the model of his car. he's basically saying if he can use a standard model's radiator with the b16 then you should be fine with an HF one.
STD also stands for sexually transmitted disease, it can be bought from any cheap ***** for a low price.
Old Nov 20, 2003 | 07:16 AM
CRX Spaz's Avatar
It will work, shortly after I did my B16 swap in my Si the radiator rotted out and I bougth a double ply from http://www.Absoluteradiator.com at it works great, cheap too.
Old Nov 20, 2003 | 09:53 AM
JrCRXHF's Avatar
i ran my old hf radiator and it was fine for a while then it started to leak but that was beause of age i have a si radiator that is brand new it has about 700miles on it because just after that i put a turbo on my car and had to get the 99-00 si radiator so let me know if you want it and i will make you a deal.
Old Nov 20, 2003 | 11:37 AM
R6Boy69's Avatar
here is the best thing to do... go out and get a 90-93 integra rad... they are dual core and mount the EXACT same as a CRX rad... then you can use the 90-93 integra B series rad hoses and they fit perfectly on the rad and the B16... just like stock... no need to have to stretch the tiny crx rad hoses...
crxracer2006
Sep 28, 2005 07:43 AM
teknoracing
Aug 28, 2005 01:11 AM
Chicano
Apr 21, 2005 04:54 PM
b16EF
Oct 21, 2002 12:00 PM
