noobie me
im getting a front sway bar for free and wondering is it hard to put it on... i searched... nothing came up... what do i need to install it ( like extra bolts n stuff ).. or a link would help
If you're getting it brand new you shouldn't have a problem with the hardware required for it and it's not hard to put on. Everything is straight forward but since you're getting it for free and you might not get all the hardware for it that might be a problem finding the little stuff like the bolts but you should be able to use your existing bolts from the stock sway bar. Of course this is if you get a swaybar that is a straight bolt-on. Hope so, good luck
If you're getting a larger sized swaybar you might need a kit for it to fit along with preventing it from tearing out the subframe.
Cheers
Modified by JDM_Honda_Fiend at 11:42 AM 11/19/2003
Cheers
wat car do you have (year and model). what sway bar are you getting? i hope ur not gettign anything bigger than you already have. it will make the car understeer more. if anything leave the stock (22 or 24mm) and upgrade the rear to an ITR 22 or 23mm. make sure u get a beaks kit with it (helps prevents tearout)
warfa
May 13, 2003 06:33 PM
